Arduino Nano strange behavior
Hi
I`m new to the Arduino and just started practicing simple use of PWM and pin input/output.
I got a really strange behavior with the led fading program that I`m runing when a pin is LOW.
When I disconnect the pin from GROUND when the led is fading dow and I put it back to GROUND the led is flashing really fast like in a loop . To get out of this loop I have to disconect the pin for a couple of seconds .
here is my code
int led = 5;           // the PWM pin the LED is attached to
int test ;
int brightness = 0;    // how bright the LED is
int fadeAmount = 5;    // how many points to fade the LED by
// the setup routine runs once when you press reset:
  pinMode(led, OUTPUT);
  pinMode(6,INPUT);
  pinMode(9,OUTPUT);
  digitalWrite(6, HIGH);
// the loop routine runs over and over again forever:
  // read input pin 6
  test = digitalRead(6);
  if (test == LOW ) {
  analogWrite(led, brightness);
  // change the brightness for next time through the loop:
  brightness = brightness + fadeAmount;
  // reverse the direction of the fading at the ends of the fade:
  if (brightness <= 0 || brightness >= 255) {
    fadeAmount = -fadeAmount;
  // wait for 30 milliseconds to see the dimming effect
  delay(30);
  if (test != LOW ){
    brightness=0;
    analogWrite(led, 0);
    delay(2);
Post your code with auto format and in [code ] [/ code] blocks.
  pinMode(6,INPUT);
  pinMode(9,OUTPUT);
You set 6 as input, but then write to it?
What pin are you disconnecting?
Do not modify a live/powered cirquit.
Danois90:
I use put Pin 6 to ground ... it`s an input not really chanching the ciruit.
Writing HIGH to the pin is to use the pull-up resistor .
Doing that activates the built in pullup resistor. Equivalent to the more explicit
pinMode(6, INPUT_PULLUP);
Incidentally, it seems a shame not to give all of the pins meaningful names
This is confusing too
  // set the brightness of pin 9:
Comments should at the very least match the code.
Sorry for the comments I will change them. But you can clearly see what I want to do with the code ..
I just did a proper button debounce and it does the same thing
dnenov7:
Post the latest version of your program which takes account of the comments already made.
...R
The problem is being caused by setting brightness to zero when fadeAmount happens to be -5
0 - 5 is -5 (ie less than 0) so fadeAmount is changed to 5
-5 + 5 is 0 (ie equal to 0) so fadeAmount is changed to -5
and so on for ever
Also note that when the int -5 (0xFFFB) is used as a PWM value it gets truncated to a byte (0xFB) and treated as unsigned so the value is 251. You're toggling between a very low brightness (5) and a very high brightness (251).
Big tnx to UKHeliBob & UKHeliBob
Problem resolved :slight_smile:
