HI
I have got an Arduino nano clone and one of my sketches randomly stop running after some time, when I press reset button it starts but will stop again in same way, even though it does run fine on the Arduino Uno, here is the sketch and the schematic
the circuit is just a simple fade but I have added a button to control the on and off of the LED
thanks
Debounce
Each time the input pin goes from LOW to HIGH (e.g. because of a push-button
press), the output pin is toggled from LOW to HIGH or HIGH to LOW. There's a
minimum delay between toggles to debounce the circuit (i.e. to ignore noise).
The circuit:
- LED attached from pin 13 to ground
- pushbutton attached from pin 2 to +5V
- 10 kilohm resistor attached from pin 2 to ground
- Note: On most Arduino boards, there is already an LED on the board connected
to pin 13, so you don't need any extra components for this example.
created 21 Nov 2006
by David A. Mellis
modified 30 Aug 2011
by Limor Fried
modified 28 Dec 2012
by Mike Walters
modified 30 Aug 2016
by Arturo Guadalupi
This example code is in the public domain.
http://www.arduino.cc/en/Tutorial/Debounce
// constants won't change. They're used here to set pin numbers:
const int buttonPin = 2; // the number of the pushbutton pin
const int ledPin = 6; // the number of the LED pin
int brightness = 0; // how bright the LED is
int fadeAmount = 5; // how many points to fade the LED by
// Variables will change:
int ledState = HIGH; // the current state of the output pin
int buttonState; // the current reading from the input pin
int lastButtonState = LOW; // the previous reading from the input pin
// the following variables are unsigned longs because the time, measured in
// milliseconds, will quickly become a bigger number than can be stored in an int.
unsigned long lastDebounceTime = 0; // the last time the output pin was toggled
unsigned long debounceDelay = 50; // the debounce time; increase if the output flickers
pinMode(buttonPin, INPUT);
pinMode(ledPin, OUTPUT);
// set initial LED state
digitalWrite(ledPin, ledState);
// read the state of the switch into a local variable:
int reading = digitalRead(buttonPin);
// check to see if you just pressed the button
// (i.e. the input went from LOW to HIGH), and you've waited long enough
// since the last press to ignore any noise:
// If the switch changed, due to noise or pressing:
if (reading != lastButtonState) {
// reset the debouncing timer
lastDebounceTime = millis();
if ((millis() - lastDebounceTime) > debounceDelay) {
// whatever the reading is at, it's been there for longer than the debounce
// delay, so take it as the actual current state:
// if the button state has changed:
if (reading != buttonState) {
buttonState = reading;
// only toggle the LED if the new button state is HIGH
if (buttonState == HIGH) {
ledState = !ledState;
// set the LED:
// digitalWrite(ledPin, ledState);
//Serial.println(ledState);
if (ledState == HIGH){
FadeInOut();
analogWrite(ledPin, 0);
brightness = 0;
// save the reading. Next time through the loop, it'll be the lastButtonState:
lastButtonState = reading;
void FadeInOut(){
// set the brightness of pin 9:
analogWrite(ledPin, brightness);
// change the brightness for next time through the loop:
brightness = brightness + fadeAmount;
Serial.println(brightness);
// reverse the direction of the fading at the ends of the fade:
if (brightness <= 0 || brightness >= 255) {
if (brightness < 0) {brightness = 0;}
//if(brightness = 255) {delay(500);}
fadeAmount = -fadeAmount;
//Serial.println(fadeAmount);
// wait for 30 milliseconds to see the dimming effect
delay(50);
