I am having trouble getting this code to upload to the Arduino Nano. I have many comments in my code including a header section which lists the hardware I am using. I have tried using ATmega328P (Old Bootloader), ATmega328P, and ATmega168. The attempt using ATmega328P did get stuck in uploading, whereas none of the other attempts produced this effect. Given my post was too long with the code and all three error messages, I have attached my code and only included the error message using ATmega328P.
Here is the error message with ATmega328P.
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Nicholus\Documents\Arduino\libraries -fqbn=arduino:avr:nano:cpu=atmega328 -vid-pid=0000_0000 -ide-version=10812 -build-path C:\Users\Nicholus\AppData\Local\Temp\arduino_build_818450 -warnings=none -build-cache C:\Users\Nicholus\AppData\Local\Temp\arduino_cache_149845 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino5.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\Nicholus\Desktop\arduino sketches\Project Sketches\Proj01 - Under Bed Path Illumination\Proj01_REV00\Proj01_REV00.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Nicholus\Documents\Arduino\libraries -fqbn=arduino:avr:nano:cpu=atmega328 -vid-pid=0000_0000 -ide-version=10812 -build-path C:\Users\Nicholus\AppData\Local\Temp\arduino_build_818450 -warnings=none -build-cache C:\Users\Nicholus\AppData\Local\Temp\arduino_cache_149845 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino5.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\Nicholus\Desktop\arduino sketches\Project Sketches\Proj01 - Under Bed Path Illumination\Proj01_REV00\Proj01_REV00.ino
Using board 'nano' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Using core 'arduino' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Detecting libraries used...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10812 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "C:\\Users\\Nicholus\\AppData\\Local\\Temp\\arduino_build_818450\\sketch\\Proj01_REV00.ino.cpp" -o nul
Generating function prototypes...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10812 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "C:\\Users\\Nicholus\\AppData\\Local\\Temp\\arduino_build_818450\\sketch\\Proj01_REV00.ino.cpp" -o "C:\\Users\\Nicholus\\AppData\\Local\\Temp\\arduino_build_818450\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\Nicholus\\AppData\\Local\\Temp\\arduino_build_818450\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10812 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "C:\\Users\\Nicholus\\AppData\\Local\\Temp\\arduino_build_818450\\sketch\\Proj01_REV00.ino.cpp" -o "C:\\Users\\Nicholus\\AppData\\Local\\Temp\\arduino_build_818450\\sketch\\Proj01_REV00.ino.cpp.o"
Compiling libraries...
Compiling core...
Using precompiled core: C:\Users\Nicholus\AppData\Local\Temp\arduino_cache_149845\core\core_arduino_avr_nano_cpu_atmega328_0c812875ac70eb4a9b385d8fb077f54c.a
Linking everything together...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\\Users\\Nicholus\\AppData\\Local\\Temp\\arduino_build_818450/Proj01_REV00.ino.elf" "C:\\Users\\Nicholus\\AppData\\Local\\Temp\\arduino_build_818450\\sketch\\Proj01_REV00.ino.cpp.o" "C:\\Users\\Nicholus\\AppData\\Local\\Temp\\arduino_build_818450/..\\arduino_cache_149845\\core\\core_arduino_avr_nano_cpu_atmega328_0c812875ac70eb4a9b385d8fb077f54c.a" "-LC:\\Users\\Nicholus\\AppData\\Local\\Temp\\arduino_build_818450" -lm
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\\Users\\Nicholus\\AppData\\Local\\Temp\\arduino_build_818450/Proj01_REV00.ino.elf" "C:\\Users\\Nicholus\\AppData\\Local\\Temp\\arduino_build_818450/Proj01_REV00.ino.eep"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-objcopy" -O ihex -R .eeprom "C:\\Users\\Nicholus\\AppData\\Local\\Temp\\arduino_build_818450/Proj01_REV00.ino.elf" "C:\\Users\\Nicholus\\AppData\\Local\\Temp\\arduino_build_818450/Proj01_REV00.ino.hex"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-size" -A "C:\\Users\\Nicholus\\AppData\\Local\\Temp\\arduino_build_818450/Proj01_REV00.ino.elf"
Sketch uses 1146 bytes (3%) of program storage space. Maximum is 30720 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM4 -b115200 -D -Uflash:w:C:\Users\Nicholus\AppData\Local\Temp\arduino_build_818450/Proj01_REV00.ino.hex:i
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM4
Using Programmer : arduino
Overriding Baud Rate : 115200
Proj01_REV00.ino (1.55 KB)
