i have Arduino Nano, and i try to upload the code but i have always the same problem:
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xa4
that happend till 10 times
i have bought a new cable, i have updated the drivers, i choose tool-> arduino nano -> atmega 328 (because it is), and the port is OK.
i have tried make a reset before upload and nothing...
i have tried also make a reset when apperas the first error message and nothing...
I don´t understand and i don´t know what happend and what can i do.
I found these links for burning the firmware again. I already have a Usbasp programmer (RioRand®USB ASP ISP Downloader 51 AVR Programmer) and I am just waiting for some other stuff to finish so I can reboot after installing firmware for it. Will report back later. But these links may get you started.
Your IDE is probably trying to talk to a FT232R serial chip, and your nano may not have that chip. Lots of China nanos have been substituting the CH340G serial chip, which does not work the same. Can you tell which chip is on your nano ? The big chip on the bottom of the nano.
Jack, mine has the CH340G and it shows that in the Device Manager under LPT ports.
The thing is that until about midday yesterday it was all working fine, then win8/Arduinon-IDE would not display a Port for it.
I searched around and tried everything short of burning the boot loader. Nothing worked. So, finally, it was the turn of the boot loader option. My USBbus programmer was no use as the firmware said it was out of date and I could not find any that would work, so then opted for the Uno approach.
After following the instructions to burn the boot loader with my Uno, I get these errors. The Pin-13 LED on both devices flashes at about once per second. It is entirely possible the $8-thing just died after working for a while so I have ordered a couple more. But, I'd like to try and resolve this as it may help others who can't wait the five days for another Nano to arrive.
Verbose Errors:
Arduino: 1.6.5 (Windows 8.1), Board: "Arduino/Genuino Uno"
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -cstk500v1 -PCOM4 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0x05:m -Uhfuse:w:0xDE:m -Ulfuse:w:0xFF:m
avrdude: Version 6.0.1, compiled on Apr 15 2015 at 19:59:58
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM4
Using Programmer : stk500v1
Overriding Baud Rate : 19200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x03
avrdude done. Thank you.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
I have no idea where that came from. I have always used 9600 and the Device Manager is showing 9600 for Port 5. I figured the Programmer for burning the boot loader was communicating somehow with the Nano to get that setting. The Tx and Rx lights on the Uno flash very briefly a few times so there seems to be some exchange of something.
Nope, the LED just flashes in unison with the LED on the Uno in boot loader programming mode. Looks about 200Msec on, 600-Msec off on both boards.
Yup, Uno is working fine on Port 4, the Nano on Port 5 is not happy at all.
I'll try changing that baud rate in Device Manager.
OK, no difference with changing baud rate other than now not getting the 19200 message. Seems like it is a brick, albeit a tiny brick.
I also have problem with Arduino please try to provide possible solution... my scenario is that I've programmed nano on breadboard working without problem... but when put it on Veroboard, Solder it, then that programmed Arduino no more working... I've tried to re-burn the program to it on soldered Arduino that was also not able to program... where as same program is working on my other boards I have... error message arrived after taking few time showing Uploading... that is same as above shown or some times 0x05 like errors etc... what's the possible solution to correct this thing now???
