Arduino nano using HW RX to forward GPS output
Hi there!
Long story short: I want to use hardware RX of atmega to recieve TX from Neo-6M GPS device.
Testing everything with softwareSerial example works:
#include <SoftwareSerial.h>
SoftwareSerial mySerial(2, -1); // RX, TX
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  Serial.println("Goodnight moon!");
  // set the data rate for the SoftwareSerial port
  mySerial.begin(9600);
  mySerial.println("Hello, world?");
void loop() { // run over and over
  if (mySerial.available()) {
    Serial.write(mySerial.read());
  if (Serial.available()) {
    mySerial.write(Serial.read());
but after swiching wire to RX and to this schetch:
char character;
  gpsSerial.begin(9600);
  Serial.println("Hi!");
  if (Serial.available()) {     // If anything comes in Serial1 (pins 0 & 1)
    character = Serial.read();
    Serial.write(character);   // read it and send it out Serial (USB)
it stops.
Neo is 3v3 device - might it be a problem?
Best regards!
Tx from PC is going to the same Rx pin, so you have conflicting signals.
I know it is! But I'm not sending anything via PC (and won't in my project). Is there any solution for doing that with non-modified NANO. In future I'll use here barebone atmega, so there will be no RS-USB converter.
