Arduino Nano V3.0 fails to upload the blink example
I bought from eBay an Arduino Nano V3.0 with the CH430 USB chip. My laptop immediately recognizes the Arduino's COM port as COM3.
Board: "Arduino Nano"
Programmer: "AVRISP mkii"
Processor: "Atmeg328P"
Port: "COM3"
When I attempt to upload the blink example to the board, I get the below errors. Please advise. Thank you!
Sketch uses 924 bytes (3%) of program storage space. Maximum is 30720 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
C:\Users\ale2\dev\Arduino\hardware\tools\avr/bin/avrdude -CC:\Users\ale2\dev\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM3 -b115200 -D -Uflash:w:C:\Users\ale2\AppData\Local\Temp\arduino_build_122058/Blink.ino.hex:i
An error occurred while uploading the sketch
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\ale2\dev\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM3
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x96
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x96
Ok, apparently the Arduino Nano (cheapo knocked off ones from eBay both China and USA sellers) from eBay must be used with OLD bootloader.
The solution was to choose "Tools -> Processor -> Atmega328P (Old Bootloader)" option, and should flash the program nicely.
C:\Users\ale2\dev\Arduino\hardware\tools\avr/bin/avrdude -CC:\Users\ale2\dev\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM3 -b57600 -D -Uflash:w:C:\Users\ale2\AppData\Local\Temp\arduino_build_122058/Blink.ino.hex:i
Using Port : COM3
Overriding Baud Rate : 57600
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Arduino
Description : Arduino
Hardware Version: 2
Firmware Version: 1.16
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file "C:\Users\ale2\AppData\Local\Temp\arduino_build_122058/Blink.ino.hex"
avrdude: writing flash (924 bytes):
Writing | ################################################## | 100% 0.30s
avrdude: 924 bytes of flash written
avrdude: verifying flash memory against C:\Users\ale2\AppData\Local\Temp\arduino_build_122058/Blink.ino.hex:
avrdude: load data flash data from input file C:\Users\ale2\AppData\Local\Temp\arduino_build_122058/Blink.ino.hex:
avrdude: input file C:\Users\ale2\AppData\Local\Temp\arduino_build_122058/Blink.ino.hex contains 924 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 0.22s
avrdude: verifying ...
avrdude: 924 bytes of flash verified
avrdude done. Thank you.
