Arduino Nano v3 atmega 328p avrdude: stk500_getsync(): not in sync: resp=0x00
i get this error:
when trying to upload a example sketch.
pin (0,1) are not occupied; it is the right serial port with latest drivers i choosed the right board
The RX led blinks 2 or 3 times when i try to upload.
Full log:
avrdude: Version 5.11, compiled on Sep 2 2011 at 19:38:36 Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/ Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "D:\Utz\Downloads\arduino-1.0.4\hardware/tools/avr/etc/avrdude.conf"
Using Port : \.\COM3
Using Programmer : arduino
Overriding Baud Rate : 57600
avrdude: Send: 0 [30] [20] avrdude: Send: 0 [30] [20] avrdude: Send: 0 [30] [20] avrdude: Recv: avrdude: stk500_getsync(): not in sync: resp=0x00
avrdude done. Thank you.
woops, don't know why search didn't show up with it but manual look does: Unable to flash demo sketch to Nano V3 - IDE 1.x - Arduino Forum very simmilar problem, but no working solution..
also tried what is described on the last answer : http://arduino.alt245.com.ar/how-i-dealt-with-this-error/ :confused:
Moderator edit: session id removed
Does the loopback test pass or fail?
http://forum.arduino.cc/index.php?topic=73748.0
In short I shell just:
connect the two upper left
connect the two upper right but one (in other words: second and third from top on the right side )
pins and then connect it to the pc and send someething via terminal ?
Laboratory just closed, looking for some jumper from my old pc
//EDIT:
found them. did the test with arduino serial monitor. Letters just disappear after pressing SEND no ECHO :confused:
What version of the FTDI VCP drivers do you have installed?
http://www.ftdichip.com/Drivers/VCP.htm
You could try updating the FTDI drivers.
I installed them just a few hours ago, they are up to date :confused: Also tried it on my notebook and on every usb slot
2.08.28 for 64 bit Windows
@muhkuharduino: seems we have the same problem, just one topic away:
http://forum.arduino.cc/index.php?topic=165924.0
loopbacktest fails for me
There is some indication in this thread that going back to 2.08.24 fixed his problem:
http://forum.arduino.cc/index.php?topic=165310.msg1238147#msg1238147
ECHO is working now with 2.08.24! but Uploading still doesn't
Can confirm Loopback with 2.08.24 here!
WTF
yesterday I was working on my desktop computer.. I just installed the old drivers on my laptop AND RESTARTED (as I were requested) and changed the baudrate from 9600 to 57600 under device manager -> comport. (dont thing this is neccessary)
AND IT WORKS! Upload is working just fine!
ps: just in case i would have shortened the bottom+top ICSP pins on the right and those on the left while connected via usb but my upload still works: could something be damaged ?
I had no success so far. Duzends of reboots, using FTDI drivers 2.8.24.0 and changing the port to 57600 bps did not solve the problem for me...
I'm sorry to hear that. Maybe you should then mark it as defect and claim for a new working one :confused:
I got my USBtinyISP with that one I'm able to flash my sketches through this ISP programmer!
And I got a new Nano V3 (the third one - same brand, two different suppliers) - still unable to flash directly via FTDI/USB.
Either the FTDI/UART-Interface of the complete series is broken or it's a driver issue.
I tried 2.8.28 and 2.8.24 from this source: VCP Drivers - FTDI, the 2.8.28 from Windowsupdate (which seems to be the same as the one provided by ftdi), and the 2.8.14 shipped with arduino IDE. The COM-port is set up correctly without errors for all three of them, but while flashing via usb I still get the message:
Reflashing the bootloader works, but does not solve the problem.
I have no plan how to get that to work, still I would be happy for any hint...
Can you provide a link to the Nano's you have?
Are these official Arduino Nano's or clones?
Which bootloader are you flashing onto them?
Since you are able to flash sketches with the ISP, can you verify the serial interface is working by flashing a sketch that uses the serial interface and interact with the Nano using the Serial Monitor. Start with the ASCIItable example or something similar to that.
This will help narrow down if you are having problems with the USB - serial interface or if it is isolated to the bootloader.
Mine looks a little bit different, here is a picture: http://image-upload.de/image/7JTtWt/bed6e86995.jpg
They are clones
To the first I flashed the default bootloader shipped with arduino 1.0.4 (Select Arduino Nano w/ ATmega328), Tools "install bootloader". The second one has the untouched bootloader which was shipped with the divice. (Third arduino went back to supplier)
I have flashed ASCIItable onto both. Arduino Serial Monitor is showing lots of blanks. RealTerm shows me 8448 "NUL" Values. TX led on Nano is on while transmitting.
Thanks for your help!
It seems like the baud rate is off by a factor of 33 between the FTDI and the 328.
If you load the blink sketch and have it set for 1 second On and Off, does the LED blink at 1 second intervals?
I made a messurement with the blink sketch over several minutes, the timing of the 328 seems ok, 1000ms on the 328 equals 1 second in real live...
Hi, I had similar problems with two Nanos from ebay. (W7, 64bit and XP, FTDI driver Version 2.08.28)
I used the exe installer from the FTDI site to install the previous driver version.
This solved my problems.
http://www.ftdichip.com/Drivers/CDM/CDM20824_Setup.exe
(Changing only the comport driver in the device manager didn't work for me)
Thank's for that hint - I used the .exe but I had no success.
I found out that changing comportdriver and .exe didn't change all files of the driver. I manually replaced the files with the ones shipped by ftdi with 2.08.24 and I'm running the following driver files right now (all placed under C:\Windows\system32):
  • drivers/ftser2k.sys Version 2.08.24 by FTDI Ltd.
  • drivers/serenum.sys Version 6.1.7600.16385 (win7_rtm.090713-1255) by Microsoft Corporation
  • ftcserco.dll Version 2.01.03.1 by FTDI Ltd.
  • ftserui2.dll Version 2.08.23 by FTDI Ltd.
Still having the same problem...
