arduino nano v3 pinout identification for pinMode
Arduino nano v3 pinout confusion
int ledMedGreen = 10;
int ledMedGreen1 = 11;
  //dow Sunday,= 1
  pinMode(ledMedGreen, OUTPUT);
  pinMode(ledMedGreen1, OUTPUT);
IN loop section i have
 digitalWrite(ledMedGreen, HIGH);
    digitalWrite(ledMedGreen1, HIGH);
    digitalWrite(ledMedGreen, LOW);
    digitalWrite(ledMedGreen1, LOW);
My question is the identification for the physical pin connection
When looking at the pinout diagram is is unclear why there are numbers in magenta has it is not defined in the legend.
I got my project working and found the physical pint for ledMedGreen = 10 and ledMedGreen1 =11
Am I correct in saying that only physical pins in magenta can be set via pinmode ?
opale7000:
I agree that's unnecessarily confusing. Other than that the pighixxx diagrams are great but that's always bothered me.
opale7000:
First of all, calling them "physical pins" is wrong. The term "physical pin" refers to the actual pin numbering on the IC (gray in the diagram), which is completely different from the Arduino pin numbering in magenta. You can use the teal An numbers too if you like but keep in mind that A6 and A7 can only be used as
analog inputs.
