Hi!
I am new to Arduino and need some valuable guidance.
I am currently working on a new project which requires Bluetooth connection between 2 points.
Point 1 - Nano with HC05
Point 2 - Nano with HC05
Action taken so far
- Connect Arduino Nano using the mini USB cable to PC and loaded an empty code - Success
- Unplug USB cable and connect Arduino Nano chip to HC05 chip using Dupont cable (Female - Female) through below configuration
Arduino HC05
5V (Pin 27) VCC
GND (Pin 29) GND
3V3 (Pin 17) EN
TX (Pin 1) TX
RX (Pin 2) RX
Observation:
LED on HC05 blink rapidly.
Corrective action:
Remove USB cable from Arduino Nano chip
Unplug the 5V (Pin 27) from Arduino Nano chip
Insert USB cable back to Arduino Nano chip
Press and hold the black button on HC05 while inserting back the 5V (Pin 27) (LED on HC05 slowdown and stable).
After which, I open up Serial monitoring windows from the Arduino software and trying to enter the AT command, it does not respond in any manner. I repeated the same AT command for all other baud rate and it doesn't work as well. Both NL & CR are selected throughout the process.
Appreciate if anyone can advise me on where did i do wrong?
Thanks in advance.
