Arduino Nano with Lego Accelerometer
I don't know how many people have actually done this, but my day was spent getting this to work.
So to start with, you need to cut a lego cable
Soldering/tinning the ends works best :wink:
Then, with a breadboard most likely, connect the pins 1 and 4 to 5v, 2 and 3 to ground, 5 and 6 to I2C clock and data respectively.
Then the code:
#include "Wire.h"
  Wire.begin();
  Serial.begin(19200);           // start serial for output
  Wire.beginTransmission(1); // transmit to device #1(lego accelerometer
  Wire.send(0x42);           // sends Read first 8 bits of accelerometer
  Wire.endTransmission();
  delay(700);
  Wire.requestFrom(1, 8);
  while(Wire.available())
    char c = Wire.receive();
    Serial.println(c,HEX);    //output the data
  Serial.print("Done \n");
Fairly simple, but I had trouble googling it, so I did it myself
The rest of the request bytes can be found on the hitechnic site
Always glad to help
~Nai
You might have to take a look at the datasheet on the accelerometer, for the I2C connection. Are you receiving any type of data back? If so, will you post it.
Nope, got it working. One of the wires was broken inside the connector.
Also, for anyone else doing this here's the code:
#include "Wire.h"
  Wire.begin();
  Wire.send(0x42);
  delay(20);
  Wire.requestFrom(1, 1);
  char b;
    b = Wire.receive();
  delay(50);
  Wire.send(0x45);
  delay(20);
    int i = (c & 3) + (b << 2);
    Serial.println(i,DEC);
