Hi guys,
My Hardware:
Arduino Nano with ATmega328
OLED Display 128x32 with SSD1306
I used the code from here Arduino Nano with SSD1306 I2C OLED Analog Display with. The code works well. What I don't like is, that the code uses 49% of the arduino storage. Is there a better code for OLED with SSD1306 which does not use so much storage.
I don't need to display images on the OLED. I just want to write some letters and numbers on the OLED.
Here is the code:
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
//#include <Adafruit_BME280.h>
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 32 // OLED display height, in pixels
#define OLED_RESET -1 // Reset pin # (or -1 if sharing Arduino reset pin)
#define SCREEN_ADDRESS 0x3C ///< See datasheet for Address; 0x3D for 128x64, 0x3C for 128x32
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
// SSD1306_SWITCHCAPVCC = generate display voltage from 3.3V internally
if (!display.begin(SSD1306_SWITCHCAPVCC, SCREEN_ADDRESS))
Serial.println(F("SSD1306 allocation failed"));
for (;;); // Don't proceed, loop forever
// Show initial display buffer contents on the screen --
// the library initializes this with an Adafruit splash screen.
display.display();
delay(2000); // Pause for 2 seconds
// Clear the buffer
display.clearDisplay();
// Draw a single pixel in white
display.drawPixel(10, 10, SSD1306_WHITE);
// Show the display buffer on the screen. You MUST call display() after
// drawing commands to make them visible on screen!
display.display();
delay(2000);
testdrawstyles(); // Draw 'stylized' characters
void testdrawstyles(void)
display.setTextSize(1); // Normal 1:1 pixel scale
display.setTextColor(SSD1306_WHITE); // Draw white text
display.setCursor(0, 0); // Start at top-left corner
display.println(F("Hello, world!"));
//(SSD1306_BLACK, SSD1306_WHITE); // Draw 'inverse' text
display.println(3.141592, 6); //6-digit after decimal point
display.setTextSize(2); // Draw 2X-scale text
display.print(F("0x")); display.println(0xDEADBEEF, HEX);
display.display();
delay(2000);
