Sketch uses 3244 bytes (10%) of program storage space. Maximum is 30720 bytes.
Global variables use 371 bytes (18%) of dynamic memory, leaving 1677 bytes for local variables. Maximum is 2048 bytes.
"C:\Users\kenzo\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude" "-CC:\Users\kenzo\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf" -v -V -patmega328p -carduino "-PCOM4" -b57600 -D "-Uflash:w:C:\Users\kenzo\AppData\Local\Temp\arduino\sketches\3A57A96DB333520751C63EB7B09A1F2D/bluetooth_test.ino.hex:i"
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\kenzo\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
Using Port : COM4
Using Programmer : arduino
Overriding Baud Rate : 57600
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xc1
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xc1
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xc1
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xc1
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xc1
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xc1
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xc1
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xc1
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xc1
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xc1
avrdude done. Thank you.
Failed uploading: uploading error: exit status 1
i used to be able to upload the basics blink example code to it using the old bootloader but now nothing
