Arduino Nano
I am new to this, I have an Uno and I love it and works great. I just purchased a few Arduino Nano's and I was wondering how to upload a sketch. I am running Windows 10 just fyi.
I tried uploading a sketch and got the following error:
"vrdude: ser_open(): can't open device "\.\COM3": The system cannot find the file specified."
Also when I plug the Nano in I get nothing under the tools>ports in the Arduino software.
What can I do to fix this issue?
I have an Adafruit Trinket that is giving me the same problem even though I have the drivers. When I plug the Trinket in my computer doesn't recognize it at all and I get nothing under tools>ports in the Arduino software.
Your Nanos probably have the CH340 USB-serial chip. You need to install the driver for it:
http://www.wch.cn/download/CH341SER_EXE.html
The Adafruit Trinket works differently from standard Arduino boards. It won't cause a port to appear, that's normal. You just need to select Tools > Programmer > USBtinyISP and then upload. For more information see:
Hey,
While uploading the code, try to remove the Vin connection and then upload.
Once uploading the code is done, then connect the Vin and check the working.
Regards.
TMTiger24:
Hey,
Regards.
Where do you see that it's powered from Vin?
aladny:
Your first step should be to check Windows Device manager. It might show under other devices which would indicate that you need a driver (see pert's reply above).
