arduino navigation using x y coordinates
Hello everyone,
I am planning to move my bot in a certain path. I have mounted three led's on the bot and able to track it's position as x y coordinates using IR camera located at the top of the arena.
Using these positions I would like to move bot in a certain path. My bot has two DC motors.
How can I use this position coordinates to move bot in a certain path? May be it's a simple question, sorry I am new to this.
Have a nice weekend.
Is the IR camera linked to a PC ?
Is the PC controlling the Robot ? If so, how does the PC communicate with the Robot ?
To move the Robot in a specific direction you will first have to know what direction it is pointing. The x y coordinates will not tell you that.
I guess you could move a short distance in a straight line and figure out the orientation from the changes to the coordinates. Then you could "remember" the orientation.
In simple terms the control system will probably be
  • move a bit
  • check the new coordinates
  • calculate the next movement
  • repeat
...R
Hello Robin2
Thank you very much for your reply.
Robin2: Is the IR camera linked to a PC ?
Yes IR camera linked to a PC, IR camera setup with ROS camera package finds LED positions on the arena.
Robin2: Is the PC controlling the Robot ?
Yes
Robin2: If so, how does the PC communicate with the Robot ?
Using bluetooth
Do I need to use triangulation or something to find the orientation of the robot?
Thanks.
If you have a differential drive robot, then the math is pretty simple for steering. See this intro: http://rossum.sourceforge.net/papers/DiffSteer/
You do need to know the robot orientation and could get that using image processing on the PC. Have the 3 LEDs in a unique arrangement so that the robot orientation can be determined directly from the bright points on the image.
rosdino: Do I need to use triangulation or something to find the orientation of the robot?
As @jremington said, if you can put a distinctive pattern of lights on the robot the PC may be able to determine the orientation from the image.
If that is not an option I think the only thing to do is what I suggested in Reply #1
The examples in serial input basics (preferrably the 3rd) should be useful for receiving data from the PC
...R
Kirishimaza: A good web site is informative and useful.
We are.
...R
