Arduino Network causing severe battery drain on WiFi connected devices.
Not quite... Wake-On-Lan is to remotely turn on a device (such as a laptop or PC that's turned off / hibernated / suspended). They would normally completely ignore all network traffic, including ARP broadcasts, unless it received a "Magic Packet": Wake-on-LAN - Wikipedia
What I'm talking about is a bit different. When a modern mobile device, such as an Android phone or iPhone, isn't doing anything, it goes into a low power state - essentially dropping the CPU clock speed down to something very small, turning off circuits that aren't needed, reducing the RAM refresh, etc.
When they receive an ARP broadcast though, they will go to full speed so that they can deal with it. It is normally advantageous for the device to stay at full speed for a while so that other processes can catch up and not immediately require it to wake up again (as powering up everything causes a reasonably battery hit on its own). So it'll normally stay awake for a few seconds, then go back into a power save mode. I can't speak for all devices, but on my phone it'll stay awake for at least a few seconds when woken up. So, sending frequent broadcasts to the device that require it to wake up can cause it to stay fully awake forever.
This is exactly what's happening with me based on the following evidence:
  • The logs show that its being woken up constantly due to receiving stuff on the WiFi.
  • The log entries are timed at exactly the same frequency that my Arduino is sending stuff.
  • Wireshark shows the Arduino sending those ARP broadcasts at the same frequency and times that my phone is being woken up.
  • If I disconnect the Arduino from the network, the battery lasts around around 20x longer. When it's disconnected the remaining WiFi RX wakelocks account for almost no power use (under 2% of total battery use).
  • If I reconnect the Arduino the battery life sucks again.
  • It's not just my phone, but several mobile devices in the household that exhibit exactly the same behaviour.
That is what I meant. I didn't know exactly what the term would be for that. It must be a "wake-on-something" tho. How about "wake-on-arp"?
From the device's perspective they're called "Wakelocks". Or specifically in this case WLAN_RX_WAKE Kernel Wakelocks. The device is in full power mode while a Kernel Wakelock is held. You can also have Partial Wakelocks which can be held by applications.
I'll go with that. "Wakelock" appears to be specifically an Android term, but it sounds good. Almost all Google search items involved Android.
So it seems your alternative is to isolate your wireless devices from the ethernet devices. I'm not sure how to stop the w5100 from doing the ARP broadcast, but I will take a look.
It comes down to 4 choices (in order of my preference):
  • Fix / Improve the Arduino Ethernet module so that it caches ARP entries. This would be the way most devices work.
  • Find some way to add a static ARP entry on the Arduino Ethernet so it never has to send out the broadcast.
  • Add another router to make a network segment that I can put all the misbehaving network devices on.
  • "Isolate" my WiFi so that WiFi devices can only access the internet and not the LAN.
Buying a router costs me money and uses up more space, power sockets, cabling.
Isolating my WiFi is a no good for me as my WiFi devices need access to the LAN (e.g. printers, remote desktop, NAS, etc).
So I'm hoping for one of the top 2. I've failed to find anything myself though. :frowning:
I'm experienced with the w5100 and w5200 versions of the ethernet library, and I do not see where the arduino or wiznet library code is involved with an arp broadcast. I think that is done by the w5100 firmware internally when it establishes the connection.
The w5100 doesn't have a bunch of internal SRAM. Most is taken by the 4 socket buffers. It doesn't leave much for arp lists. :frowning:
You told you can log into your router by telnet and have a linux environment there? Do you have root access then? If yes, you probably can segment your WLAN from your LAN without loosing connectivity. You just have to remove the (software) bridge between the interfaces and enable ip_forward on the router. Configure two subnets and you're fine.
It seems to be root access. While I'm very familiar with Linux, I've never had to do that kind of stuff on it before. However, I'm also chatting to a guy who makes one of the more popular custom firmwares for it to see if he can help.
I wonder if an iptables rule could filter it...
You probably don't need iptables for that. Does the router have the "ip" command? Can you post the output of "ip ro sh"?
You'll understand if I blank out some of the IPs :slight_smile:
So it's obviously bridged the relevant devices (giving br0). At this point I'm getting scared to bugger around with it :smiley:
admin@RT-N66U:/tmp/home/root# ip ro sh
217.X.X.X dev ppp0 proto kernel scope link src VincentMcKenzie'sWAN-IP
192.168.0.0/24 dev br0 proto kernel scope link src 192.168.0.1
169.254.0.0/16 dev eth0 proto kernel scope link src 169.254.128.143
127.0.0.0/8 dev lo scope link
default via 217.X.X.X dev ppp0
Sure, didn't expect anything else.
No reason to get scared. At this level (without saving anything) if anything goes wrong, just unplug your router from power and replug it, it will boot in a state as it was before.
We have to split the WLAN interface from the bridge. The command f
or this is:
brctl delif br0 <wlan-interface>
where stands for the name of the wireless interface. The command
iwconfig
should give you the list of your interfaces, all marked "no wireless extensions." are not of interest. You probably have only one with more information, that's your WiFi interface.
Before you split the bridge with the above command, issue the following command to activate ip forwarding (router functionality). Although this is probably already the case, it's just a precaution.
echo "1" > /proc/sys/net/ipv4/ip_forward
If you've done this, your WiFi interface should be in a separate segment. We still need to configure ip addresses and we have to check what netfilter rules are active.
To do all the commands be sure to use one of the ethernet ports on the router, do not use your WLAN for that, because that might be interrupted during the commands.
If you've done the above, please post the output of the following commands (again: changing public IPs to placeholders is perfectly viable):
ifconfig
iptables -L -n
Not true with all routers. If I modify a setting, there is no need to save. Unless I am in safe mode, the change is immediate and permanent. Good thing I have a serial port to access the router to get the default config back.
Otherwise, it is no big thing as long as you can afford a new one.
Yeah I've changed other things on this router and changes like this are usually persistent. For example I've changed the brightness of the LEDs by simply piping numbers into the right /dev and it stays that brightness after a reboot.
If this weren't a router that I need all the time for my job I'd be more than comfortable messing around with it, but I have concerns - for example br0 is mentioned in various scripts on the device - so what happens when the web interface tries to configure stuff using these scripts that reference br0? If the bridge is split, that means there'll be two separate devices to configure but again the web interface only expects one.
There's also another problem in that I actually do need to receive some broadcasts onto my Wireless devices. For example I use an app on my phone that monitors log server broadcasts for stuff :confused:
I really wish there was a way to fix the Arduino side of this.
I do not see where the library code is involved with an ARP broadcast. I still believe that is accomplished by the firmware in the w5100.
You can check. The library code from Wiznet and Arduino is available as source code in your IDE.
/libraries/Ethernet/
and
/libraries/Ethernet/utility/
This is probably the case if you use the Web interface for configuring things. But if you use the command line I haven't seen a device yet that automatically saves that in a non-volatile storage.
I didn't write you should reboot the device but unplug from power. That way there's no possibility to shutdown the device and store current settings in EEPROM or flash.
After doing such stuff on the command line you shouldn't use the web interface to configure the device. I just wanted to give you an opportunity to use your current device and have the segments separated.
I don't see a chance to change anything on the Arduino side. Embedded devices usually don't have enough memory to cache an ARP table.
I have used many brands of routers, and now I use MikroTik routers. They work really well. I do not use the web interface. I am a CLI kinda guy. Here is a topic on another forum that describes what I do when I lock myself out of one of my remote routers:
http://forum.mikrotik.com/viewtopic.php?f=2&t=29388&p=142934&hilit=curse#p142934
Without the serial cable, the router would be bricked.
Unless you are in safe mode, the changes are immediate and permanent.
Is that MikroTik router running Linux? It doesn't look like to me. If I change configuration file that are stored in the flash file system changes are permanent. But by just issuing commands to devices I just change a state and this state-change is volatile.
I believe it is a highly modified Linux, but that is really not the point. The OP stated that he changed a setting, and without saving anything, it kept that setting through a reboot. That is a good sign that it is saving that setting without a "save" command.
That's a good sign that it save it during a reboot but not on a power cycle. The commands I posted are standard Linux commands, none of them is saving anything. But the OP doesn't seem to be interested, so we're just loosing time here.
Changes made are saved in a device mapped off /dev/nvram, which I assume is "Non-volatile RAM". All changes you make on this router are persistent even after a power cycle.
But yes, I don't want to waste anyone's time. I'm not comfortable messing around with this router like that, especially given the references to br0 in so many places.
If there's no way to fix it from the Arduino side I'll "borrow" a router from work and if that fixes it stick with that.
Seriously though - this thread has been very valuable to me, and I greatly appreciate everyone's help.
