Arduino newbie
Helo!
I have used atmega128 with stk500 for a lego line follower robot,But now im starting a project to make a wireless water well level sensor with ultrasonic sensor and zigbee. I am now trying to find out which microcontroller to use,and Arduino seems realy intresting since its so compact and that it has so many shields.
My queastion is: whats the difference in programming "normal" atmega microcontrollers And arduino?Can i just program it as other atmegas or Do i have to use special arduino codes?
thanks!
Take a look at some of the samples. The IDE that comes with the Arduino uses a dialect of C called “wiring” (I think?)
In any case, it’s standard C minus some headers and the code:
int main() { setup(); for (;:wink: loop() }
This is passed to avr-gcc.
tl;dr I don’t think there’s any difference. They provide a somewhat simplified environment but I don’t think you have to use it.
int main() { setup(); for (;;) loop() }
sp.int main() { init (); setup(); for (;;) loop(); }
According to
…\arduino-0018\hardware\arduino\cores\arduino
it´s
#include <WProgram.h>
int main(void)
      init();
      setup();
      for (;;)
            loop();
      return 0;
Isn´t it?
