[Hi. I am looking around for a RFID/NFC reader for arduino and I found this one: RFID Reader - Adafruit
The question I had was will I be able to use the input pins for other things like a weight sensor, or does the shield take up all of the inputs?
This shield is designed to use I2C or SPI communication protocols. I2C is the default, as it uses fewer pins: analog 4 and 5 are used for I2C (of course you can still connect other I2C devices to the bus). Digital #2 is used for "interrupt" notification.
So in the default setup (I2C), this shield uses:
analog 4
analog 5
digital 2
