Arduino NG Code not running on Mini
Hi!
I have some code interfacing with a touchpad PS/2 using interrupts. The Code is running on the NG pretty good but on the Mini it won’t work! Any idea why? Is there a difference the Mini deals with interrupts?
#define LOOP_DELAY 100
#define SEND_BYTES_DELAY 20
//The time from the rising edge of a clock pulse to a Data transition must be at least 5 microseconds.
#define DATA_TO_FALLING_DELAY 5
//The time from a data transition to the falling edge of a clock pulse must be at least 5 microseconds and no greater than 25 microseconds.
#define RISING_TO_DATA_DELAY 15
#define Z_TRESHOLD 10
#define PAD_IDLECOUNTER_MAX 3
// define data and clock pin (RELATIVE - NOT ABSOLUTE, add 0 (pad1) or 1 (pad2))
// Pad1 CLK  = 2 + 0 = PIN2
// Pad1 DATA = 4 + 0 = PIN4
#define MDATA 10
#define MCLK 3
// define variables that change during interrupt
volatile boolean read_pad0 = false;
// define global variables
boolean parityError[2];
int x[2], y[2], z[2];
boolean bl[2], br[2], f[2];
int idlecounter_pad0 = 0;
byte inByte = 0x00;
// the interrupt routines
void interrupt0() {
  detachInterrupt(0);
  golo(2); //go low to put a hold on the incoming data...
  read_pad0 = true;
// get parity errors recognized
int isParityOdd(byte p) {
  p = p ^ (p >> 4); //continuously Xor until the last bit is parity
  p = p ^ (p >> 2);
  p = p ^ (p >> 1);
  return p & 1;
// basic ps2-functions
void gohi(int pin)
  DDRD &= ~(1<<pin); //set pin as input
void golo(int pin)
  DDRD |= (1<<pin); //set pin as output
  PORTD &= ~(1<<pin);//golo
void isfalling(int pin)
  while(PIND & (1<<pin))
    ; //when received bit is 1
void isrising(int pin)
  while(!(PIND & (1<<pin)))
    ; //when received bit is 0
void onelo(int pad)
  DDRD &= ~(1<<MDATA + pad); //set pin as input
  DDRD &= ~(1<<MCLK + pad); //set pin as input
  while(!(PIND & (1<<MDATA + pad)) || !(PIND & (1<<MCLK + pad)) )
char mouse_read(int pad)
  char response = 0x00;
  int response_array[8];
  int j =0;
  int i = 0;
  int parity = 0;
  int calc_parity = 0;
  for (j=0;j<8;j++) //clear the array initially
    response_array[j] = 0;
  isfalling(MCLK + pad); // wait for low clock
  delayMicroseconds(DATA_TO_FALLING_DELAY);
  //the first bit is the start bit, no need to store it
  isrising(MCLK + pad); //when the clock rises again
  delayMicroseconds(RISING_TO_DATA_DELAY);
  //here the touchpad begins setting the data bits
RX_Bits:
  isfalling(MCLK + pad); //when the clock falls begin reading--host always reads data when the clock is low
  delayMicroseconds(DATA_TO_FALLING_DELAY); //delay a bit to be sure that we never read on a clock edge
  if (i==8){ //receive the parity bit if i==8 (all 8 data bits have been received)
    if (PIND & (1<<MDATA + pad))
      parity = 1;
      parity = 0;
  }//end if i==8
  else{
      response_array[i] = 1;
      response_array[i] = 0;
  }//end else
  isrising(MCLK + pad); //wait for clock line to rise before moving on--touchpad always changes  data when the clock is high
  if (i<8){
    i++;
    goto RX_Bits;
  }//end if
  isfalling(MCLK + pad); //now wait for the clock line to fall for the stop flag
  //here is the stop flag
  isrising(MCLK + pad); //wait for clock to rise, and the stop has been received
  //layMicroseconds(35);
  //we've received all 8 data bits and the parity bit
  //translate that into a char
  if (response_array[0])
    response |= 0x01;
  if (response_array[1])
    response |= 0x02;
  if (response_array[2])
    response |= 0x04;
  if (response_array[3])
    response |= 0x08;
  if (response_array[4])
    response |= 0x10;
  if (response_array[5])
    response |= 0x20;
  if (response_array[6])
    response |= 0x40;
  if (response_array[7])
    response |= 0x80;
  //calculate parity
  calc_parity = !(isParityOdd(response));
  //and check to make sure received parity is the same as calculated parity
  parityError[pad] = calc_parity != parity;
  return response;
}//end get_response
void mouse_write(byte data, int pad)
  int i;
  int parity = 1;
  gohi(MDATA + pad);
  gohi(MCLK + pad);
  delayMicroseconds(300);
  golo(MCLK + pad);
  golo(MDATA + pad);
  delayMicroseconds(10);
  /* start bit */
  gohi(MCLK + pad);
  /* wait for mouse to take control of clock); */
  /* clock is low, and we are clear to send data */
  for (i=0; i < 8; i++) {
    if (data & 0x01) {
      gohi(MDATA + pad);
    else {
      golo(MDATA + pad);
    /* wait for clock cycle */
    parity = parity ^ (data & 0x01);
    data = data >> 1;
  /* parity */
  if (parity) {
    gohi(MDATA + pad);
  else {
    golo(MDATA + pad);
  /* stop bit */
  gohi(MDATA + pad);
  delayMicroseconds(50);
  /* wait for mouse to switch modes */
  onelo(pad);
  /* put a hold on the incoming data. */
  golo(MCLK + pad);
  /* read acknowledge byte */
  mouse_read(pad);
  //  Serial.print("done.\n");
…2.part of the code
void pad_init(int pad)
  byte response;
  gohi(MCLK + pad);
  gohi(MDATA + pad);
  delayMicroseconds(200);
  //Serial.print("# Resetting PAD ");
  //Serial.println(pad);
  mouse_write(0xff, pad); /* > reset */
  response = mouse_read(pad);      /* < blank AA*/
  response = mouse_read(pad);      /* < blank 00*/
  mouse_write(0xe9, pad); /* > status */
  response = mouse_read(pad);      /* < blank 02*/
  response = mouse_read(pad);      /* < blank 64*/
  mouse_write(0xf5, pad); // > disable /
  mouse_write(0x26, pad); // > not defined
  response = mouse_read(pad);      /* < blank 88*/
  response = mouse_read(pad);      /* < blank 05*/
  response = mouse_read(pad);      /* < blank VERSIONNUMBER*/
  mouse_write(0xf4, pad); // > enable
  Serial.print("# PAD READY ");
boolean read_absolute_remote_mode(int pad)
  byte c1, c2, c3, c4, c5;
  boolean totalParityError = false;
  gohi(MCLK + pad);                               // The clock signal must be continuously in high level...
  delayMicroseconds(70);                          // for at least 50 microseconds before the device can start transmitting the data.
  DDRD &= ~(1<<MCLK + pad);                       // release clock by setting it input... ready to receive data
  /* get a reading from the mouse */
  c1 = (byte)mouse_read(pad);
  totalParityError |= parityError[pad];
  c2 = (byte)mouse_read(pad);
  c3 = (byte)mouse_read(pad);
  c4 = (byte)mouse_read(pad);
  c5 = (byte)mouse_read(pad);
  if (!totalParityError && (c5 & 128) < 1) // update coords only if no error
    x[pad] = (c1 & 127) + ((c3 & 120) << 4);
    y[pad] = (c2 & 127) + ((c4 & 120) << 4);
    z[pad] = (c5 & 127);
    bl[pad]   = (c3 & 1) > 0;
    br[pad]   = (c3 & 2) > 0;
    if(z[pad]>Z_TRESHOLD)
      f[pad] = true;
      f[pad] = false;
    return totalParityError;
void readTouchpad1()
  if (read_pad0){
    read_absolute_remote_mode(0);        // read pad0
    read_pad0 = false;                     // reset the ready-to-send variable
    attachInterrupt(0, interrupt0, LOW);   // attach interrupt again (got detached befor..)
  else {
    idlecounter_pad0++;                    // count how many times the pad didnt got read
  if(idlecounter_pad0 > PAD_IDLECOUNTER_MAX){
    f[0] = false;                          // more than x times? finger-var has to be 0
    idlecounter_pad0 = 0;                  // reset idlecounter
void serialOutput()
  Serial.print(x[0], DEC);
  Serial.print("\t");
  Serial.print(y[0], DEC);
  Serial.print("\t");
  Serial.print(z[0], DEC);
  Serial.print("\n");
  pad_init(0);                             // set modes on pad 0
  // init interrupt
  attachInterrupt(1, interrupt0, LOW);     // enable interrupt on pin 2
  readTouchpad1();                         // get data if pad is ready to send
  delay(10);                               // artificial delay...
  serialOutput();                          // send all the values to application
There shouldn't be. Are you sure you have it wired correctly? Do you have an ATmega8 or ATmega168 on the NG?
Everything is wired correctly. i checked and rewired everything a hundret times. The NG has an Atmega8 chip. Is there a difference between the external interrupt pins on the Mini and the NG?
The external interrupt pins should be more or less the same, but it’s a different chip, so there are likely to be many things that are slightly different between the two that could cause problems. What exactly happens differently?
OK I got it! It has nothing to do with the Mini or the ATmega16/8. Its the pins! I’m using 1 interrupt pin and 1 of the other DPs. The data-pin is working on 4,5,6,7 - NOT on any higher pin! Is there any reason why? Same with Mini and NG.
