Hello,
I am trying to compile and flash an I2C Temperature sensor to Arduino MKR1000 and Nano33IoT and i Get an error as above.
I can compile and flash the code in a normal Arduino Uno and it works fine. Just for the MKR1000 and Nano33IoT it is giving an error.
Please see below and advise.
/home/builder/opt/arduino-builder/arduino-builder -compile -core-api-version 10611 -hardware /home/builder/opt/arduino-builder/hardware -hardware /home/builder/.arduino15/packages -tools /home/builder/opt/arduino-builder/tools -tools /home/builder/.arduino15/packages -built-in-libraries /home/builder/opt/libraries/latest -logger humantags -fqbn arduino:samd:mkr1000 -build-cache /tmp -build-path /tmp/483655470/build -verbose -prefs runtime.tools.CMSIS.path=/home/builder/.arduino15/packages/arduino/tools/CMSIS/4.5.0 -prefs runtime.tools.CMSIS-Atmel.path=/home/builder/.arduino15/packages/arduino/tools/CMSIS-Atmel/1.2.0 -prefs runtime.tools.arduinoOTA.path=/home/builder/.arduino15/packages/arduino/tools/arduinoOTA/1.2.1 -prefs runtime.tools.arm-none-eabi-gcc.path=/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4 -prefs runtime.tools.bossac.path=/home/builder/.arduino15/packages/arduino/tools/bossac/1.7.0-arduino3 -prefs runtime.tools.openocd.path=/home/builder/.arduino15/packages/arduino/tools/openocd/0.10.0-arduino7 -prefs runtime.tools.flashpack.path=/home/builder/.arduino15/packages/Intel/tools/flashpack/2.0.0 -prefs runtime.tools.arc-elf32.path=/home/builder/.arduino15/packages/Intel/tools/arc-elf32/1.6.9+1.0.1 -prefs runtime.tools.nrf5x-cl-tools.path=/home/builder/.arduino15/packages/arduino/tools/nrf5x-cl-tools/9.3.1 -prefs runtime.tools.arm-linux-gcc.path=/home/builder/.arduino15/packages/arduino/tools/arm-linux-gcc/4.9.3 -prefs runtime.tools.dfu-util.path=/home/builder/.arduino15/packages/arduino/tools/dfu-util/0.9.0-arduino1 -prefs runtime.tools.arduino101load.path=/home/builder/.arduino15/packages/Intel/tools/arduino101load/2.0.1 -prefs runtime.tools.sketchUploader.path=/home/builder/.arduino15/packages/Intel/tools/sketchUploader/1.6.2+1.0 -prefs runtime.tools.x86-linux-gcc.path=/home/builder/.arduino15/packages/arduino/tools/x86-linux-gcc/7.2.0 -prefs runtime.tools.esptool.path=/home/builder/.arduino15/packages/esp8266/tools/esptool/2.5.0-3-20ed2b9 -prefs runtime.tools.xtensa-lx106-elf-gcc.path=/home/builder/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-3-20ed2b9 -prefs runtime.tools.core2-32-poky-linux.path=/home/builder/.arduino15/packages/Intel/tools/core2-32-poky-linux/1.6.2+1.0 -prefs runtime.tools.i586-poky-linux-uclibc.path=/home/builder/.arduino15/packages/Intel/tools/i586-poky-linux-uclibc/1.6.2+1.0 -prefs runtime.tools.avrdude.path=/home/builder/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino8 -prefs runtime.tools.avr-gcc.path=/home/builder/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5 -prefs runtime.tools.linuxuploader.path=/home/builder/.arduino15/packages/arduino/tools/linuxuploader/1.5.1 -prefs runtime.tools.mkspiffs.path=/home/builder/.arduino15/packages/esp8266/tools/mkspiffs/2.5.0-3-20ed2b9 -libraries /tmp/483655470/custom -libraries /tmp/483655470/pinned /tmp/483655470/H206_Temp_apr28a
Using library arduinoeccx08_1_3_3 at version 1.3.3 in folder: /home/builder/opt/libraries/latest/arduinoeccx08_1_3_3
Using library SPI at version 1.0 in folder: /home/builder/.arduino15/packages/arduino/hardware/samd/1.8.4/libraries/SPI
/home/builder/opt/libraries/latest/grove_barometer_hp20x_1_0_0/HP20x_dev.cpp: In constructor 'HP20x_dev::HP20x_dev()':
/home/builder/opt/libraries/latest/grove_barometer_hp20x_1_0_0/HP20x_dev.cpp:33:22: error: no matching function for call to 'TwoWire::TwoWire()'
In file included from /home/builder/opt/libraries/latest/grove_barometer_hp20x_1_0_0/HP20x_dev.h:14:0,
from /home/builder/opt/libraries/latest/grove_barometer_hp20x_1_0_0/HP20x_dev.cpp:13:
/home/builder/.arduino15/packages/arduino/hardware/samd/1.8.4/libraries/Wire/Wire.h:35:5: note: candidate: TwoWire::TwoWire(SERCOM*, uint8_t, uint8_t)
TwoWire(SERCOM *s, uint8_t pinSDA, uint8_t pinSCL);
/home/builder/.arduino15/packages/arduino/hardware/samd/1.8.4/libraries/Wire/Wire.h:35:5: note: candidate expects 3 arguments, 0 provided
/home/builder/.arduino15/packages/arduino/hardware/samd/1.8.4/libraries/Wire/Wire.h:32:7: note: candidate: constexpr TwoWire::TwoWire(const TwoWire&)
class TwoWire : public Stream
/home/builder/.arduino15/packages/arduino/hardware/samd/1.8.4/libraries/Wire/Wire.h:32:7: note: candidate expects 1 argument, 0 provided
/home/builder/.arduino15/packages/arduino/hardware/samd/1.8.4/libraries/Wire/Wire.h:32:7: note: candidate: constexpr TwoWire::TwoWire(TwoWire&&)
exit status 1
