[Arduino noob] a simple code but I just don't know how to do
#include "SparkFun_Qwiic_Step.h" //Click here to get the library: http://librarymanager/All#Qwiic_Step by SparkFun
QwiicStep motor;
int run;
int buttonPin;
  run = 0; //starts stopped
   buttonPin = 2; //whatever pin your button is plugged into
   pinMode(buttonPin, INPUT_PULLUP);
  Serial.println("Qwiic step examples");
  Wire.begin();
  //Check if Qwiic Step is correctly connected to I2C
  if (motor.begin() == false)
    Serial.println("Device did not acknowledge! Freezing.");
    while (1)
  Serial.println("Motor acknowledged.");
  //code you always run here; you can leave this section blank if you want the entire program to stop and start, or add code here if you want it to always run
  //check button press here and if it is pressed then toggle run variable between 0 and 255; REQUIRED!
  if(digitalRead(buttonPin) == LOW) //funcitons based off of button pulling input pin LOW
     if(run == 0)
         run = 255;
         run = 0;
  if(run > 0)
     //code you only run if button was pressed, stops running when button pressed again, so forth...
    motor.move(700); //Turn one exact rotation of a 200 step stepper motor
  //Motor will be moving...
I copy the example code from Arduino libraries and from other users.
Press the bottom then the stepper motor will run for a certain rotation. (here is 700)
then stop, then if i press again it will rotate another 700, repeat the same process.
that's it. but the code above happens to keep running forever when i press the bottom.
Have a look at the digital input examples in the IDE and get that working to say flash the internal LED on pin 13.
Then have a look at the stepper examples .
Getting other peoples code often can be frustrating , better to write your own
hammy:
thanks for your help. I'll look it up
These links may help.
Stepper Motor Basics
Simple Stepper Code
When looking for help about stepper motors it is a good idea to provide a link to the datasheet for the stepper motor as there are hundreds of different models. Also tell us what stepper motor driver you are using.
…R
