I hope this is the right place for this (if not -- mods plz move, thanks!). I built a "Zorkduino" (GitHub - rossumur/Zorkduino: Play Zork on your TV with an Arduino.). This is the second time I've done this; the first one, a few years ago, something shorted out the regulator on my eBay Arduino Nano and fried the board ![]()
I got the code to compile (thankfully, my old thread from arguing with the code, that last time, was still extant!) and I got it to upload, with some difficulty. HOWEVER, something at a hardware level is not functioning correctly.
I followed the schematic at the Git repository very closely. The only modifications are:
(1) The audio lead is not going to an RCA output through a resistor, but directly to a small piezo element. (One of the little black can ones.)
(2) The video goes directly (through appropriate resistors, however) to a seven-inch 480x234 cheap trash composite LCD monitor I got off of eBay. The monitor requires 12v power, so power and power-ground are off the 12v rail of a dual-voltage power supply, and everything else in the circuit is at 5v, including the signal ground of the LCD. I have checked with various listings for identical monitors, and my example should be pulling about 6w (0.5a) at 12v.
(3) The previously-mentioned 5v rail is switched on and off by a small SPST rocker switch. As the LCD has its own internal power switch, I saw no need of a DPDT switch or anything to (further) switch the 12v rail.
(4) The whole thing is built into the inside of a SolidTek ACK-595 PS/2 keyboard, except the LCD, which is mounted on laptop hinges atop the keyboard.
(5) Not really a deviation, but the required SD card is a 32mb model, formatted FAT16 through gparted (I use Linux) and it is known good with the requisite files onboard.
I am powering the whole thing from a standard LaCie power brick, using the appropriate (Kycon aka "Power DIN" four-pin) connector. This brick is rated 12v 2.0a 5v 2.2a. When I plug it in, the LCD displays a severely horizontally distorted "No signal" message. Turning on the 5v rail's power switch "stabilizes" (for lack of a better term) the screen, but it still reads "No Signal". Interestingly, if I power it from a LaCie "Bigger Disk" brick (12v 3.0a 5v 4.3a), the brick power-cycles rather than applying steady power.
The only thing I can think of is some sort of 'back-feed' sort of situation through the LCD, where, maybe, both grounds are shorted together for expediency and that that's responsible for the mess.
Photos upon request, but please bear in mind that (a) I'm a quite poor photographer and (b) this thing is a truly masterful rat's nest inside.
