Here is the Arduino Code:
int xpinClk = 6;
int xpinDir = 8;
int ypinClk = 5;
int ypinDir = 7;
int zpinClk = 4;
int zpinDir = 9;
int pinStop = 2;
int StepsX;
int StepsY;
int StepsZ;
int PauseBtwPoints;
int targetStepsX;
int targetStepsY;
int targetStepsZ;
int xPos = 0;
int yPos = 0;
int zPos = 0;
int xInc;
int yInc;
int zInc;
int y_last = 0;
int y_move;
int endStop;
int MoveDelay = 400; //This controls the speed of the scanner.
pinMode(xpinClk,OUTPUT);
pinMode(xpinDir,OUTPUT);
pinMode(ypinClk,OUTPUT);
pinMode(ypinDir,OUTPUT);
pinMode(zpinClk,OUTPUT);
pinMode(zpinDir,OUTPUT);
pinMode(pinStop,INPUT);
digitalWrite(pinStop,HIGH);
Serial.setTimeout(10);
Serial.flush();
SetToHome();
//This is the main code that will run for each coordinate.
while(Serial.available() < 1){ //Wait for a data point to be sent over serial
Serial.print("after while");
StepsX = Serial.parseInt(); //X value in steps
Serial.print(StepsX);
StepsY = Serial.parseInt(); //Y value in steps
StepsZ = Serial.parseInt(); //Z value in steps
PauseBtwPoints = Serial.parseInt(); //Delay in milliseconds
targetStepsX = StepsX - xPos; //Calculate target X value using current X position.
targetStepsY = StepsY - yPos; //Calculate target Y value using current Y position.
targetStepsZ = StepsZ - zPos; //Calculate target Z value using current Z position.
MoveXMot(targetStepsX);
MoveYMot(targetStepsY);
Serial_flush();
void MoveRotMot(int steps)
int k = 1;
if(steps > 0){
digitalWrite(zpinDir,HIGH);
for( k; k <=(StepsZ); k++)
digitalWrite(zpinClk,HIGH);
delayMicroseconds(MoveDelay);
digitalWrite(zpinClk,LOW);
else{
if(steps < 0){
digitalWrite(zpinDir,LOW);
for( k; k >=(StepsZ); k--)
void Serial_flush(){
while(Serial.available()>0){
Serial.read();
delay(PauseBtwPoints); //Delay to give positions time to settle.
Serial.println(1); //Print value to line telling MATLAB to continue
void SetToHome(){
//Set X Home
endStop = digitalRead(pinStop);
Serial.print(pinStop);
digitalWrite(xpinDir,LOW);
while(endStop != 1){
digitalWrite(xpinClk,HIGH);
digitalWrite(xpinClk,LOW);
digitalWrite(xpinDir,HIGH);
for(int j=1;j<=50;j++){
xPos = 0;
//Set Y home
digitalWrite(ypinDir,LOW);
digitalWrite(ypinClk,HIGH);
digitalWrite(ypinClk,LOW);
digitalWrite(ypinDir,HIGH);
for(int l=1;l<=50;l++){
yPos = 0;
void e_STOP(){
while(1){
void MoveXMot(int stepsX)
// endStop = digitalRead(pinStop);
//if(endStop == 1){
// e_STOP();
if(stepsX > 0){
for( int k; k <=(stepsX); k++)
else{
if(stepsX < 0){
for( int k; k >=(stepsX); k--)
void MoveYMot(int stepsY)
if(endStop == 1){
e_STOP();
if(stepsY > 0){
for( int k; k <=(stepsY); k++)
else{
if(stepsY < 0){
for( int k; k >=(stepsY); k--)
And here is the Matlab Code:
%Clear command window and workspace
clc
clear all
%Determine data entry mode
disp('RUNNING XYZ MODE');
mode = input('Please enter 0 for manual entry or 1 to read a file containing [x y z delay] data in inches and milliseconds.\n\n');
if mode == 0
x = input('Please enter x value inches.\n\n');
y = input('Please enter y value in inches.\n\n');
z = input('Please enter z value in degrees.\n\n');
delay = 0;
position_data = [x,y,z,delay];
rows = 1;
elseif mode == 1
%Loads a text file with a user interface and saves the data into
%a variable called 'data'. Thanks to Mike Robinson for the code for this
%section
[filePath,pathName] = uigetfile('.txt'); %Get file path and path name
position_data = dlmread(strcat(pathName,filePath)); %open file
delay = position_data(:,4);
[rows, n] = size(position_data);
disp('Please enter 0 for manual entry or 1 to read a file\n\n')
end
%Define the limits in inches of the scanner
x_limit = 35.6;
y_limit = 35.6;
%Find the indices of values that are outside of the scanner bounds
ix = find(position_data(:,1) > x_limit);
iy = find(position_data(:,2) > y_limit);
%Find the x and y values that are outside of the scanner bounds
bad_x_vals = position_data(ix,1);
bad_y_vals = position_data(iy,2);
if ((ix ~= 0) | (iy ~=0)) %If there is at least one value outside of the range
for c = 1:length(ix) %Display x-values and indices that exceed range
disp(['Your x values of ' num2str(bad_x_vals(c)) ' inches with index ' ...
num2str(ix(c)) ' are out of the ' num2str(x_limit) ' inch range. Please revise.'])
end
for c = 1:length(iy) %Display y-values and indices that exceed range
disp(['Your y values of ' num2str(bad_y_vals(c)) ' inches with index ' ...
num2str(iy(c)) ' are out of the ' num2str(y_limit) ' inch range. Please revise.'])
end
error('Exiting m-file') %Exit the m-file35
else %If no values are outside the range
disp('All values are within bounds of scanner!') %Let the user know the scan will proceed
end
%Convert position data to step information
stepsPerInch = 500; %Define scanner resolution
stepsPerDegree = 67;
step_data_x = stepsPerInch*position_data(:,1); %Convert x direction to steps
step_data_y = stepsPerInch*position_data(:,2); %Convert to steps
step_data_z = stepsPerDegree*position_data(:,3); %Convert to steps
%Add in delay column
Arduino_data = [step_data_x step_data_y step_data_z delay];
s = serial('COM4','BaudRate',9600); %Establish serial with COM6, Arduino's serial port, with Baud rate 9600.
set(s,'InputBufferSize',512); %Establish a 512 byte buffer to read data back from Arduino.
fopen(s); %Open serial connection.
pause(2); %Wait 2 seconds for Arduino to reset after opening serial connection.
for k = 1:rows %For the number of positions to go to
x_value = num2str(Arduino_data(k,1)); %Write the x-value of that position as a string.
y_value = num2str(Arduino_data(k,2)); %Write the y-value of that position as a string.
z_value = num2str(Arduino_data(k,3)); %Write the z-value of that position as a string.
delay_value = num2str(Arduino_data(k,4)); %Write the y-value of that position as a string.
fwrite(s,strcat(x_value,';',y_value,';',z_value,';', delay_value,';')); %Combine x, y and z together, separated by ;'s.
while(s.BytesAvailable == 0) %While the buffer is empty (no data has been sent back)
end %Continuously wait (infinite loop).
fgets(s); %Gets ok signal from Arduino to proceed.
end
fclose(s); %Close the serial port.
Thanks for the replies so far! I will work on fixing the for loop.
