Arduino not receiving array from RF transmitter 433MHZ
Hi all,
I am currently having a problem receiving an array from my Transmitter using 433MHz. From the led on pin 13 I can see that the Arduino is transmitting but the other one is not receiving this data. Individually the program code and the RF code work, however when they are combined this problem occurs.
Transmitter:
void rfunction()
    uint8_t buf[VW_MAX_MESSAGE_LEN];
    uint8_t buflen = VW_MAX_MESSAGE_LEN;
    // Non-blocking
    if (vw_get_message(buf, &buflen))
    int i;
        digitalWrite(13, true);
        for (i = 0; i < buflen; i++)
          Sensor1CharMsg[i] = char(buf[i]);
        Sensor1CharMsg[buflen] = '\0';
        Sensor1Data = atoi(Sensor1CharMsg);
        Serial.print("Sensor 1: ");
        Serial.println(Sensor1Data);
        digitalWrite(13, false);
    output_voltage = Sensor1Data * (5 / 1023);
    wi = (6 * output_voltage);
  pinMode(ledPin, OUTPUT);
  MsTimer2::set(200, rfunction);
  MsTimer2::start();
  vw_set_ptt_inverted(true);
  vw_setup(2000);
  vw_rx_start();
  Serial.println(wi);
  delay(2000);
Receiver:
void rfunction()
    int i;
  MsTimer2::start();
  vw_setup(2000);
  vw_rx_start();
  battery_state();
  lcd.setCursor(0,1);
  lcd.print("Choose option: ");
  lcd.setCursor(0,2);
  lcd.print("1: AI 92");
  lcd.setCursor(0,3);
  lcd.print("2: Sensor Readings");
    char key = keypad.getKey();
    if(key == '1')
      battery_state();
      lcd.setCursor(0,1);
      lcd.print("Range: ");
      dist = range();
      battery_state();
      lcd.setCursor(0,1);
      lcd.print("Angle: ");
      deg = angle();
      battery_state();
      new_range = horizontal_range(dist, deg);
      temp = (temperature - Base_Temperature_C) / 25;
      hum = (humidity - Base_Humidity) / 20;
      alt = (altitude - Base_Altitude_m) / 3048;
      clicks_1 = range_clicks(new_range);
      clicks_elevation = clicks_1 + temp + hum + alt;
      clicks_wind = wind_speed(new_range, wi);
      lcd.setCursor(0,0);
      lcd.print("Elevation: ");
      lcd.setCursor(0,1);
      lcd.print("  UP ");
      lcd.print(clicks_elevation);
      lcd.print(" clicks");
      lcd.setCursor(0,2);
      lcd.print("Windage: ");
      wind_dir(clicks_wind);
    if(key == '2')
      battery_state();
      lcd.setCursor(0,0);
      lcd.print("Temp = ");
      lcd.print(temperature);
      lcd.print(" *C");
      lcd.setCursor(0,1);
      lcd.print("Pressure = ");
      lcd.print(pressure);
      lcd.print("hPa");
      lcd.setCursor(0,2);
      lcd.print("Altitude = ");
      lcd.print(altitude);
      lcd.print(" m");
      lcd.setCursor(0,3);
      lcd.print("Humidity = ");
      lcd.print(humidity);
      lcd.print(" %");
      delay(2000);
void battery_state()
lcd.clear();
int val = analogRead(A0);
float batt = (val / 1023.00) * 9.00;
if(batt >= 8.00)
    lcd.setCursor(19,0);
    lcd.write((uint8_t)0);
else if((batt < 8.00) && (batt >= 6.50))
    lcd.write((uint8_t)1);
    lcd.write((uint8_t)2);
int range()
  int i, r;
  lcd.setCursor(0,2);
  for(i=0;i<3;i++)
   keyNew[i] = keypad.waitForKey();
   lcd.print(keyNew[i]);
   count ++;
  while(count == 3)
   if(key == '#')
     count ++;
   while(count == 4)
     r = atoi(keyNew);
     count = 0;
  return r;
int angle()
  int i, a;
  lcd.setCursor(0,2);
  for(i=0;i<2;i++)
   keyNew1[i] = keypad.waitForKey();   // Stores number pressed in an array
   lcd.print(keyNew1[i]);              // Prints number pressed to the LCD
   count ++;                           // Increments the count variable by 1
  while(count == 2)
   if(key == '#')
     count ++;
   while(count == 3)
     a = atoi(keyNew1);
     count = 0;
  return a;
int horizontal_range(int num_range, int num_angle)
  int val;
  if(num_angle <= 5)
    val = num_range * 0.99;
  else if((num_angle > 5) && (num_angle <= 10))
    val = num_range * 0.98;
  else if((num_angle > 10) && (num_angle <= 15))
    val = num_range * 0.96;
  else if((num_angle > 15) && (num_angle <= 20))
    val = num_range * 0.94;
  else if((num_angle > 20) && (num_angle <= 25))
    val = num_range * 0.91;
  else if((num_angle > 25) && (num_angle <= 30))
    val = num_range * 0.87;
  else if((num_angle > 30) && (num_angle <= 35))
    val = num_range * 0.82;
  else if((num_angle > 35) && (num_angle <= 40))
    val = num_range * 0.77;
  else if((num_angle > 40) && (num_angle <= 45))
    val = num_range * 0.70;
  else if((num_angle > 45) && (num_angle <= 50))
    val = num_range * 0.64;
  else if((num_angle > 50) && (num_angle <= 55))
    val = num_range * 0.57;
  else if((num_angle > 55) && (num_angle <= 60))
    val = num_range * 0.50;
  else if((num_angle > 60) && (num_angle <= 65))
    val = num_range * 0.42;
  else if((num_angle > 65) && (num_angle <= 70))
    val = num_range * 0.34;
  else if((num_angle > 70) && (num_angle <= 75))
    val = num_range * 0.26;
  else if((num_angle > 75) && (num_angle <= 80))
    val = num_range * 0.17;
  else if((num_angle > 80) && (num_angle <= 85))
    val = num_range * 0.09;
    val = num_range * 0.01;
  return val;
RX continued:
int range_clicks(int num)
  int clicks;
  if(num <= 100)
    clicks = 0;
  else if((num > 100) && (num <= 140))
    clicks = 1;
  else if((num > 140) && (num <= 180))
    clicks = 3;
  else if((num > 180) && (num <= 220))
    clicks = 6;
  else if((num > 220) && (num <= 260))
    clicks = 9;
  else if((num > 260) && (num <= 300))
    clicks = 12;
  else if((num > 300) && (num <= 340))
    clicks = 15;
  else if((num > 340) && (num <= 380))
    clicks = 19;
  else if((num > 380) && (num <= 420))
    clicks = 23;
  else if((num > 420) && (num <= 460))
    clicks = 27;
  else if((num > 460) && (num <= 500))
    clicks = 31;
  else if((num > 500) && (num <= 540))
    clicks = 35;
  else if((num > 540) && (num <= 580))
    clicks = 40;
  else if((num > 580) && (num <= 620))
    clicks = 45;
  else if((num > 620) && (num <= 660))
    clicks = 50;
  else if((num > 660) && (num <= 700))
    clicks = 56;
  else if((num > 700) && (num <= 740))
    clicks = 62;
  else if((num > 740) && (num <= 780))
    clicks = 68;
  else if((num > 780) && (num <= 820))
    clicks = 74;
  else if((num > 820) && (num <= 860))
    clicks = 81;
  else if((num > 860) && (num <= 900))
    clicks = 88;
  else if((num > 900) && (num <= 940))
    clicks = 97;
    clicks = 105;
  return clicks;
void wind_dir(int w_clicks)
  int i;
  int w;
  lcd.setCursor(0,2);
  for(i=0;i<2;i++)
   keyNew2[i] = keypad.waitForKey();
   lcd.print(keyNew2[i]);
   count ++;
  while(count == 2)
   if(key == '#')
     count ++;
   while(count == 3)
     w = atoi(keyNew2);
     count = 0;
 if((w > 0) && (w <= 6))
  lcd.setCursor(0,3);
  lcd.print("RIGHT ");
  lcd.print(w_clicks);
 else if((w > 6) && (w <= 12))
  lcd.setCursor(0,3);
  lcd.print("LEFT");
  lcd.setCursor(0,3);
  lcd.print("ERROR re-enter value");
int wind_speed(int wind_range, int w_val)
    int clicks;
    int w;
    output_voltage = w_val * (5.0 / 1023);
    level = (6 * output_voltage);          //The level of wind speed is proportional to the output voltage.
if(wind_range < 150)
  w = 1;
else if((wind_range >= 150) && (wind_range < 250))
  w = 2;
else if((wind_range >= 250) && (wind_range < 350))
  w = 3;
else if((wind_range >= 350) && (wind_range < 450))
  w = 4;
else if((wind_range >= 450) && (wind_range < 550))
  w = 5;
else if((wind_range >= 550) && (wind_range < 650))
  w = 7;
else if((wind_range >= 650) && (wind_range < 750))
  w = 8;
else if((wind_range >= 750) && (wind_range < 850))
  w = 10;
else if((wind_range >= 850) && (wind_range < 950))
  w = 12;
  w = 13;
if(level <= 2.22)
  clicks = w;
else if((level > 2.22)&&(level < 4.44))
  clicks = w * 2;
  clicks = w * 4;
return clicks;
Under "transmitter" you have posted receiver code.
Make sure that a simple example of message transmission is working, with the same sort of message that will be sent in the full length application, before adding all the extra code.
That way, forum members can help you find problems without having to wade through hundreds of lines of irrelevant code.
