And what about the decoupling caps. How much should they be? How to calculate them if I want?
Strealmer:
You don't "want" you NEED.
RTFM.....
Tom... :o
PS. It took me a couple of minutes to capture and attach this post, yet you are prepared to wait over 3hrs here to get an answer!!!!!!!!
You even say you have seen the part of the datasheet showing the caps. don't be so (expletive deleted) lazy.
I give up.
...R
I was asking about the decoupling caps around the motors as mentioned in #22 you retard. Read carefully before you accuse.
The caps around the regulator are also doing a decoupling job.
Use 0.1uF caps on the motors.
Tom... :o
Strealmer:
Are you serious here? Didn't I just mention that I have seen the caps needed for the voltage regulator?I was asking about the decoupling caps around the motors as mentioned in #22 you retard. Read carefully before you accuse.
Post #22
PLEASE post a circuit diagram, not a Fritzy, use a pen/pencil and paper.
PLEASE what are you using as your power supplies.
PLEASE what are your motors, post link to spec/data please.
PLEASE post a picture of your project, so we can see your component layout.If you are using a 9V battery like in your Fritzy, it it cannot provide the required current.
If the regulator is fitted as in the Fritzy, where are the capacitors needed to help it regulate?
If you look at a LM7805 datasheet it will show you what capacitors are needed.Can you please tell us your electronics, programming, Arduino, hardware experience?
Is this a school/college/university project?
Thanks.. Tom...
Where did I mention caps on the motors.
Caps on the regulator yes..
Tom... ![]()
Can you PLEASE answer each of the PLEASES in my post.
(deleted)
@Strealmer will be spending some time away from the forum.
