I am using an Arduino Nano BLE 33 Sense for my project but I have a problem where the Arduino is not retaining the code after I unplug it. So in short, after uploading if connected to the computer it WORKS, if I unplug it and plug it back in the computer or any other Power sources it DOESN'T WORK. Please help.
Not knowing what your project hardware is, the first thing I do when I suspect a processor problem is to download the file/example / digital / blink without delay.
Try that and see if you get the same results.
A bit confused? Do you mean download a different file and see if it works with that
Post the code, using code tags.
#include <Arduino_APDS9960.h>
int ledState = LOW;
int Buz = 7; // Buzzer pin
unsigned long previousMillis = 0;
const long intervalLong = 1000;
const long intervalMed = 500;
const long intervalShort = 100;
while (!Serial);
if (!APDS.begin()) {
Serial.println("Error initializing APDS9960 sensor!");
// set the LEDs and buzzer pins as outputs
pinMode(LEDR, OUTPUT);
pinMode(LEDG, OUTPUT);
pinMode(LEDB, OUTPUT);
pinMode(Buz, OUTPUT);
// turn all the LEDs off
digitalWrite(LEDR, HIGH);
digitalWrite(LEDG, HIGH);
digitalWrite(LEDB, HIGH);
digitalWrite(Buz, LOW); // Initialize buzzer as OFF
// check if a proximity reading is available
if (APDS.proximityAvailable()) {
int proximity = APDS.readProximity();
if (proximity > 150) {
if (currentMillis - previousMillis >= intervalLong) {
if (ledState == LOW) {
ledState = HIGH;
ledState = LOW;
digitalWrite(LEDG, ledState);
// Turn off the buzzer
} else if (proximity > 50 && proximity <= 150) {
if (currentMillis - previousMillis >= intervalMed) {
ledState = HIGH;
ledState = LOW;
digitalWrite(LEDB, ledState);
digitalWrite(Buz, ledState);
if (currentMillis - previousMillis >= intervalShort) {
ledState = HIGH;
ledState = LOW;
digitalWrite(LEDR, ledState);
// Turn on the buzzer when the blue LED is blinking
Serial.println(proximity);
So I just uploaded the Blinkwithoutdelay example and now it works even if I unplug it and plug it back back in, however, when I tried to upload my code it doesn't even work plugged in.
Thank you so much, it is working now after uploading the blink code and reuploading my code, however, I was just wondering if you know if I can power the nano ble 33 with a 9v battery?
Yes, if you change
while (!Serial);
That is where it hangs, waiting for the serial connection to be made.
Got it
I don't really know for sure but I think it's doubtful. 9V batteries have very little energy. You would be better off with 4 AA batteries.
