It sounds like it. You can only get 500mA from the USB.
Try the distance sensor on its own to check there is no problem with that then power from an external source.
The distance sensor does work alone which proves your point.
Excuse my ignorance but what is the best way of reducing voltage? I'm thinking of hooking the distance sensor up to a 9v battery, although I'm aware it requires 5v.
From the attached picture you appear to be using a little 9v low power battery. Replace this with perhaps 6 AA cells and try again. I f you still have a problem simply take the battery power thru a 2nd 5 v regulator to power some of your external circuits.
You will need a 7805 or equivalent. The device you show appears to be a power Mosfet NOT a regulator.
That is an N channel FET - it is not a voltage regulator, therefore it is no good to you in this application unless you want to string a whole lot of other components round it.
Alright, thanks Grumpy_Mike. I couldn't find any documentation on it.
