Hi All,
I have a code that works perfectly as long as I am connected to the HC06 Bluetooth module via he Serial Bluetooth Terminal app on my phone. As soon as I go out of range the programmed sequence stops working.
The program is set to do a rotation sequence on the hour every hour. I use the Bluetooth commands to set the time and move the 'clock' into the correct position.
I have very limited knowledge of programming. My questions are:
A. does the current code attached specify to continue previous inputs via bluetooth when bluetooth is disconnected (i.e meaning I have connected the wrong wires somewhere)
B. if the current code does include this condition can I add the linked code?
C. where do I add this code - I don't know how to combine the current code with the new condition.
Any assistance would be greatly appreciated.
CURRENT CODE:
#include <SoftwareSerial.h>
#include "ds1307.h"
#define SEQ_FLAG_ADDR 0x03
#define PREV_MOVE_HOUR_ADDR 0x04
//Stepper Outputs step2,dir3
const uint8_t step_pin = 3;
const uint8_t dir_pin = 6;
const uint8_t enable_pin = 8;
uint8_t seq_flag = 0;
//Timing parameters
// const uint32_t time_between_rotations_ms = 3600*1000;
// uint32_t prev_ms = 0;
uint8_t prev_hr = 0;
//Stepper parameters
const uint16_t steps_per_rev = 1000;
const uint16_t rev_ratio = 10;
const float steps_per_deg = rev_ratio*steps_per_rev/360.0;
const uint16_t hourly_steps = (uint16_t) 390*steps_per_deg;
//Stepper Acceleration Profile
const uint16_t accel_steps = 600;
const uint16_t decel_steps = accel_steps;
const uint16_t min_speed_step_period_us = 10000;
const uint16_t max_speed_step_period_us = 2500;
const uint16_t step_period_delta_us = (uint16_t)((min_speed_step_period_us-max_speed_step_period_us)/accel_steps);
//Bluetooth Serial Setup
const uint8_t HC06_TXD_PIN = 11; //Connect to TX pin on HC06
const uint8_t HC06_RXD_PIN = 5; //Connect to RX pin on HC06
const uint8_t RX_BUFFER_SIZE = 16;
//Bluetooth Commands
const char START_CMD[] = {'s','t','a','r','t'};
const char STOP_CMD[] = {'s','t','o','p'};
const char MOVF_CMD[] = {'m','o','v','f'};
const char MOVB_CMD[] = {'m','o','v','b'};
const char SKIP_CMD[] = {'s','k','i','p'};
const char SET_MIN_CMD[] = {'s','e','t','m'};
const char SET_HR_CMD[] = {'s','e','t','h'};
//Instantiate SoftwareSerial.
SoftwareSerial hc06(HC06_TXD_PIN,HC06_RXD_PIN);
char rx_buffer[RX_BUFFER_SIZE];
uint8_t cmd_len = 0;
const char end_marker = '\n';
uint8_t rx_handle()
static uint8_t ndx = 0;
char rc;
while (hc06.available() > 0)
rc = hc06.read();
//If no newline yet
if (rc != end_marker)
rx_buffer[ndx] = rc;
ndx++;
if (ndx >= RX_BUFFER_SIZE)
ndx = RX_BUFFER_SIZE - 1;
rx_buffer[ndx] = '\0'; // terminate the string
cmd_len = ndx;
ndx = 0;
return cmd_len;
return 0;
void move(uint8_t dir, uint32_t steps)
//Enable the driver
digitalWrite(enable_pin,1);
delay(10);
//Set direction
digitalWrite(dir_pin,dir);
//If number of steps is too tiny, just move at the constant mininum rate.
if (steps < (accel_steps + decel_steps))
for (;steps>0;steps--)
digitalWrite(step_pin,1);
delayMicroseconds(min_speed_step_period_us);
digitalWrite(step_pin,0);
uint16_t step_period_us = min_speed_step_period_us;
steps-=(accel_steps+decel_steps);
//Accelerate
for (int i = accel_steps; i>0; i--)
delayMicroseconds(step_period_us);
step_period_us-=step_period_delta_us;
//Constant Velocity
for (int i = steps; i>0; i--)
//Decelerate
for (int i = decel_steps; i>0; i--)
step_period_us+=step_period_delta_us;
delay(10);
//Disable the driver
digitalWrite(enable_pin,0);
//Setup outputs
pinMode(enable_pin, OUTPUT);
pinMode(step_pin, OUTPUT);
pinMode(dir_pin, OUTPUT);
//Connect I2C
Wire.begin();
//Start serial comms with the hc06
hc06.begin(9600);
//Enable the clock.
enable_clk();
//Check DS1307 RAM if the microcontroller is in moving sequence.
seq_flag = get_ram(SEQ_FLAG_ADDR);
//Prev hour
prev_hr = get_ram(PREV_MOVE_HOUR_ADDR);
//setup:
//loop:
//if seq_flag:
//Check RAM for previous hour of move
//If current hour is new, move.
//Send
//check command from HC06
//Check for data
cmd_len = rx_handle();
//If the length of the command is >0, process the command.
if (cmd_len)
//Stop sequence
if (!strncmp(STOP_CMD,rx_buffer,4))
Serial.println(F("Stopping sequence."));
set_ram(SEQ_FLAG_ADDR,0x00);
seq_flag = 0;
//Start the sequence
if (!strncmp(START_CMD,rx_buffer,5))
Serial.println(F("Starting sequence."));
set_ram(SEQ_FLAG_ADDR,0x01);
seq_flag = 1;
//Move CCW by n degrees
if (!strncmp(MOVB_CMD,rx_buffer,4))
float angle_to_move = atof(&rx_buffer[4]);
uint32_t steps = (uint32_t) angle_to_move * steps_per_deg;
Serial.println(F("Moving CCW"));
move(0,steps);
//Move CW by n degrees
if (!strncmp(MOVF_CMD,rx_buffer,4))
Serial.println(F("Moving CW"));
move(1,steps);
//Set new minute command
if (!strncmp(SET_MIN_CMD,rx_buffer,4))
uint8_t new_min = atoi(&rx_buffer[4]);
set_min(new_min);
Serial.print(F("New time: "));
Serial.print(get_hr());
Serial.print(":");
Serial.println(get_min());
//Set new hour command
if (!strncmp(SET_HR_CMD,rx_buffer,4))
uint8_t new_hr = atoi(&rx_buffer[4]);
set_hr(new_hr);
Serial.print(":");
//Skip to next position
if (!strncmp(SKIP_CMD,rx_buffer,4))
Serial.print(F("Skipping..."));
move(1,hourly_steps);
Serial.println(F("Done with parsing."));
//If the seq flag is high and its almost moving time,
if (seq_flag && get_min() > 57)
//Check the hours
uint8_t curr_hr = get_hr();
//If the current hour is not the same as the previous hour, do the move and record a new hour.
if (curr_hr != prev_hr)
Serial.println(F("Running the hourly move."));
prev_hr = curr_hr;
set_ram(PREV_MOVE_HOUR_ADDR,prev_hr);
Serial.println(F("Done with hourly move."));
//Sleep for a little bit
delay(100);
CODING to switch from bluetooth to automated sourced from this thread: [Bluetooth Module Action when disconnected] (Bluetooth Module Action when Disconnected)
