I tried posting this on the pachube site and still no response after 3 days so I thought I would try here.
I’m having trouble getting my Arduino to talk pachube. I'm a newbie on both the Arduino and pachube and have spent hours searching so please bear with me. I’m using the Puchube client example included with the Arduino 22 and have also tried the “Arduino Ethernet with Pachube inputs and outputs” on the pachube site. I'm using a Arduino mega2560 with a standard Ethernet shield(Wiznet W5100). My feed says it’s frozen and I have no graphs displayed. The debug page shows 0 requests but a few days ago I did get an email saying I reached my rate limit but nothing showed up on my feed. Any help would be greatly appreciated.
The serial response I get is,
b5
411 Length Required
disconnecting.
connecting...
HTTP/1.1 411 Length Required
Date: Fri, 07 Oct 2011 03:07:45 GMT
Content-Type: text/html
Transfer-Encoding: chunked
Connection: close
Pachube sensor client
This sketch connects an analog sensor to Pachube (http://www.pachube.com)
using a Wiznet Ethernet shield. You can use the Arduino Ethernet shield, or
the Adafruit Ethernet shield, either one will work, as long as it's got
a Wiznet Ethernet module on board.
Circuit:
* Analog sensor attached to analog in 0
* Ethernet shield attached to pins 10, 11, 12, 13
created 15 March 2010
updated 4 Sep 2010
by Tom Igoe
http://www.tigoe.net/pcomp/code/category/arduinowiring/873
This code is in the public domain.
#include
#include
// assign a MAC address for the ethernet controller.
// fill in your address here:
byte mac[] = {
0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED};
// assign an IP address for the controller:
byte ip[] = {
192,168,1,123 };
byte gateway[] = {
192,168,1,1};
byte subnet[] = {
255, 255, 0, 0 };
// The address of the server you want to connect to (pachube.com):
byte server[] = {
173,203,98,29 };
// initialize the library instance:
Client client(server, 80);
long lastConnectionTime = 0; // last time you connected to the server, in milliseconds
boolean lastConnected = false; // state of the connection last time through the main loop
const int postingInterval = 10000; //delay between updates to Pachube.com
// start the ethernet connection and serial port:
Ethernet.begin(mac, ip);
// give the ethernet module time to boot up:
// read the analog sensor:
int sensorReading = analogRead(A0);
// if there's incoming data from the net connection.
// send it out the serial port. This is for debugging
// purposes only:
if (client.available()) {
char c = client.read();
Serial.print(c);
// if there's no net connection, but there was one last time
// through the loop, then stop the client:
if (!client.connected() && lastConnected) {
Serial.println("disconnecting.");
client.stop();
// if you're not connected, and ten seconds have passed since
// your last connection, then connect again and send data:
if(!client.connected() && (millis() - lastConnectionTime > postingInterval)) {
sendData(sensorReading);
// store the state of the connection for next time through
// the loop:
lastConnected = client.connected();
// this method makes a HTTP connection to the server:
void sendData(int thisData) {
// if there's a successful connection:
if (client.connect()) {
Serial.println("connecting...");
// send the HTTP PUT request.
// fill in your feed address here:
client.print("PUT /api/36959.csv HTTP/1.1\n");
client.print("Host: www.pachube.com\n");
// fill in your Pachube API key here:
client.print("MY PACHUBE KEY");
client.print("Content-Length: ");
// calculate the length of the sensor reading in bytes:
int thisLength = getLength(thisData);
client.println(thisLength, DEC);
// last pieces of the HTTP PUT request:
client.print("Content-Type: text/csv\n");
client.println("Connection: close\n");
// here's the actual content of the PUT request:
client.println(thisData, DEC);
// note the time that the connection was made:
lastConnectionTime = millis();
else {
// if you couldn't make a connection:
Serial.println("connection failed");
// This method calculates the number of digits in the
// sensor reading. Since each digit of the ASCII decimal
// representation is a byte, the number of digits equals
// the number of bytes:
int getLength(int someValue) {
// there's at least one byte:
int digits = 1;
// continually divide the value by ten,
// adding one to the digit count for each
// time you divide, until you're at 0:
int dividend = someValue /10;
while (dividend > 0) {
dividend = dividend /10;
digits++;
// return the number of digits:
return digits;
