Arduino novice
Hi all,
I'm new to arduino programming, so here goes.
Im trying to write a simple sketch to switch 3 solenoids on and off in sequence via a 8 channel relay module and then continual loop.
At the moment they are switching on and off at the same time.
It's a project for work.
Any help would be appreciated
Joe
joeian:
Hi all,
Joe
How have you determined they are not switching on and off in sequence?
Paul
(deleted)
The 1st solenoid valve is set at 10 bar to dump water , the second at 3 bar and the 3rd at 1 bar all to switch on for 1 minute in sequence and then repeat for 30000 cycles.
All three are switching on at the same.
joeian:
I am guessing, but it could be software related.
Paul
joeian:
If you show us the code, perhaps we can point out where the sketch is going wrong. See the topic: "How to use this forum - please read" https://forum.arduino.cc/index.php?topic=148996.0
I can't remember the code at the moment as its a work project, I will post Monday morning.
Thanks for taking the time to respond.
And, also according to the instructions, a schematic diagram of your circuit and connections, and a couple of photos so we can see how you implemented it.
Mind you, the code may be the main problem. :astonished:
