I'm a 4th grade student at the university. I can't solve the code part of my graduation project. I have 4 sensors. I get analog data from them. For example: 1.sensor:1023 2.sensor:1024 3.sensor:1023 4. sensor:1021 . I need to transfer this analog data from nrf24l01 to other nrf24l01. But I can only transfer 1 data. I want to transfer 4 of them at the same time. I've connected a capacitor to both the receiver and the transmitter.
Please help me in the code part ?
Wireless problems can be very difficult to debug so get the wireless part working on its own before you start adding any other features.
The examples are as simple as I could make them and they have worked for other Forum members. If you get stuck it will be easier to help with code that I am familiar with. Start by getting the first example to work
...R
Thank you so much for guide. I used a 10pf capacitor by mistake. I will replace the capacitor..I write here if there is a problem again. Thanks again Robin2
while (!Serial);
radio.begin();
radio.openReadingPipe(0, rxAddr);
radio.startListening();
if (radio.available())
static int text = sensor1;
radio.read(&text, sizeof(text));
Serial.println(text);
Using this code, I need to read and print values from A1, A2 and A3 analog pins, how can I write a code?
(Note:I took care of wireless problems in nrf24l01. Running smoothly.
Yes, I tried.I can read one sensor data. But I don't know what code to put the data on the 4 sensors. I'm just writing the part.My code for 1 sensor is:
Tx Code:
int sensor1;
sensor1= analogRead(A0);
radio.write(&text, sizeof(text));
RX Code:
int sensor1;
A1-A2-A3-A4 pin .I'm getting data from these pins. I want to see 4 data on a serial monitor at the receiving Arduino. Please help me coding.
