I work with a transmitter and a receiver. I have two sketches and that works fine, How can I add more arduino Nano's (receivers) ? I thought I have to work with addresses, but don't know how...
transmitter
1 - GND
2 - VCC 3.3V !!! NOT 5V
3 - CE to Arduino pin 7
4 - CSN to Arduino pin 8
5 - SCK to Arduino pin 13
6 - MOSI to Arduino pin 11
7 - MISO to Arduino pin 12
8 - UNUSED
/*-----( Import needed libraries )-----*/
#include <SPI.h> // Comes with Arduino IDE
#include "RF24.h" // Download and Install (See above)
/*-----( Declare Constants and Pin Numbers )-----*/
//None yet
/*-----( Declare objects )-----*/
// (Create an instance of a radio, specifying the CE and CS pins. )
RF24 myRadio (7, 8); // "myRadio" is the identifier you will use in following methods
/*-----( Declare Variables )-----*/
byte addresses[][6] = {"1Node"}; // Create address for 1 pipe.
int dataTransmitted; // Data that will be Transmitted from the transmitter
boolean STAT = true;
//test
int contact = 0;
void setup() /****** SETUP: RUNS ONCE ******/
pinMode(2,OUTPUT);
// Use the serial Monitor (Symbol on far right). Set speed to 115200 (Bottom Right)
Serial.println(F("RF24/Simple Transmit data Test"));
Serial.println(F("Questions: terry@yourduino.com"));
dataTransmitted = 100; // Arbitrary known data to transmit. Change it to test...
myRadio.begin(); // Start up the physical nRF24L01 Radio
myRadio.setChannel(108); // Above most Wifi Channels
// Set the PA Level low to prevent power supply related issues since this is a
// getting_started sketch, and the likelihood of close proximity of the devices. RF24_PA_MAX is default.
//myRadio.setPALevel(RF24_PA_MIN);
myRadio.setPALevel(RF24_PA_MAX); // Uncomment for more power
myRadio.openWritingPipe( addresses[0]); // Use the first entry in array 'addresses' (Only 1 right now)
}//--(end setup )---
void loop() /****** LOOP: RUNS CONSTANTLY ******/
contact=digitalRead(2);
Serial.println(contact);
dataTransmitted = contact;
myRadio.write( &dataTransmitted, sizeof(dataTransmitted) ); // Transmit the data
Serial.print(F("Data Transmitted = "));
Serial.print(dataTransmitted);
Serial.println(F(" No Acknowledge expected"));
dataTransmitted = dataTransmitted + 1; // Send different data next time
dataTransmitted = 0;
}//--(end main loop )---
/*-----( Declare User-written Functions )-----*/
//*********( THE END )***********
Receiver:
1 - GND
8 - UNUSED
//None yet
int dataReceived; // Data that will be received from the transmitter
myRadio.openReadingPipe(1, addresses[0]); // Use the first entry in array 'addresses' (Only 1 right now)
myRadio.startListening();
// initialize digital pin LED_BUILTIN as an output.
pinMode(4, OUTPUT);
if ( myRadio.available()) // Check for incoming data from transmitter
while (myRadio.available()) // While there is data ready
myRadio.read( &dataReceived, sizeof(dataReceived) ); // Get the data payload (You must have defined that already!)
// DO something with the data, like print it
if (dataReceived == 1) {
digitalWrite(4, HIGH);
Serial.print("AAN: ");
if (dataReceived == 0) {
digitalWrite(4, LOW);
Serial.print("UIT: ");
Serial.print("Data received = ");
Serial.println(dataReceived);
} //END Radio available
//None yet
