Arduino obstacle avoiding control car
my problem is the sensitivity of the sensor when detecting distance . it gets fast then it cant detect the obstacle thus it gets bump quickly
#include <SoftwareSerial.h>
SoftwareSerial BT_Serial(2, 3); // RX, TX
//motor pins
#define enA 10
#define in1 9
#define in2 8
#define in3 7
#define in4 6
#define enB 5
#define servo A4
#define echo A2    //Echo pin
#define trigger A3 //Trigger pin
int distance_L, distance_F, distance_R;
long distance;
int set = 60; //set distance 20 to 60
int bt_data; // variable to receive data from the serial port
int Speed = 90;
int mode=0;
void setup(){ // put your setup code here, to run once
pinMode(echo, INPUT );
pinMode(trigger, OUTPUT);
pinMode(enA, OUTPUT);
pinMode(in1, OUTPUT);
pinMode(in2, OUTPUT);
pinMode(in3, OUTPUT);
pinMode(in4, OUTPUT);
pinMode(enB, OUTPUT);
BT_Serial.begin(9600);
pinMode(servo, OUTPUT);
 for (int angle = 70; angle <= 140; angle += 5)  {
   servoPulse(servo, angle);  }
 for (int angle = 140; angle >= 0; angle -= 5)  {
 for (int angle = 0; angle <= 70; angle += 5)  {
void loop(){
//reads data and saves it in state
if(BT_Serial.available() > 0){
bt_data = BT_Serial.read();
Serial.println(bt_data);
if(bt_data > 20){Speed = bt_data;}
     if(bt_data == 8){mode=0; Stop();}    //Manual
else if(bt_data ==10){mode=2; Speed=90;} //Automatic Obstacle Avoiding
analogWrite(enA, Speed); // duty cycle 0 to 255 Enable Pin A for Motor1 Speed
analogWrite(enB, Speed); // duty cycle 0 to 255 Enable Pin B for Motor2 Speed
if(mode==0){
//                          Key Control
     if(bt_data == 1){forward();}  // if the bt_data is '1' the DC motor will go forward
else if(bt_data == 2){backward();}  // if the bt_data is '2' the motor will Reverse
else if(bt_data == 3){turnLeft();}  // if the bt_data is '3' the motor will turn left
else if(bt_data == 4){turnRight();} // if the bt_data is '4' the motor will turn right
else if(bt_data == 5){Stop();}     // if the bt_data '5' the motor will Stop
//                          Voice Control
else if(bt_data == 6){turnLeft();  delay(400);  bt_data = 5;}
else if(bt_data == 7){turnRight(); delay(400);  bt_data = 5;}
if(mode==2){
//                          Auto Control
 distance_F = Ultrasonic();
 Serial.print("S=");Serial.println(distance_F);
  if (distance_F > set){forward();}
    else{
      backward();
      Stop();
      Check_side();}
delay(10);
void servoPulse (int pin, int angle){
int pwm = (angle*11) + 500;      //convert angle to microseconds
 digitalWrite(pin, HIGH);
 delayMicroseconds(pwm);
 digitalWrite(pin, LOW);
 delay(50);                     //refresh the cycle of servo
long Ultrasonic(){
  digitalWrite(trigger, LOW);
  delayMicroseconds(2);
  digitalWrite(trigger, HIGH);
  delayMicroseconds(10);
  distance = pulseIn (echo, HIGH);
  return distance / 29 / 2;
void Distance(){
  if (distance_L > distance_R){
  backward();
  delay(350);
  turnLeft();
  delay(350);
 // Stop();
  //delay(350);
  else if (distance_R > distance_L){
  backward();
  delay(350);
  turnRight();
  delay(350);
 // Stop();
 // delay(350);
  else{
  backward();
  delay(300);
  //turnRight();
  //turnLeft();
  //delay(500);
void Check_side(){
    Stop();
    delay(100);
  //   backward();
  //  delay(100);
    delay(300);
    distance_L = Ultrasonic();
    delay(100);
    distance_R = Ultrasonic();
    delay(100);
    delay(300);
    Distance();
void turnRight(){
digitalWrite(in1, HIGH); //Right Motor forword Pin
digitalWrite(in2, LOW);  //Right Motor backword Pin
digitalWrite(in3, LOW);  //Left Motor backword Pin
digitalWrite(in4, HIGH); //Left Motor forword Pin
void turnLeft(){
digitalWrite(in1, LOW);  //Right Motor forword Pin
digitalWrite(in2, HIGH); //Right Motor backword Pin
digitalWrite(in3, HIGH); //Left Motor backword Pin
digitalWrite(in4, LOW);  //Left Motor forword Pin
void forward(){
void backward(){
void Stop(){
That's because you have lots of delay()'s in your code that lock up the controller so it can't respond to stuff happening in the real world.
Redesign your code so it relies less on delay(), and only use delay() for very brief intervals that don't harm your application; this is likely limited to <20ms or so.
Does the updated code have the same problem?
Probably, yes, but it's your project!
Look up on how you can replace 'delay' with a millis()-based approach.
https://www.google.com/search?q=arduino+delay+without+millis
Since you did not answer I assume all is now working
