Dear guys,
I have problem which i cant figure out.
I'm using Arduino Uno with Arduino motor shield L293D, 2 motors And 3 sonic sensors.
Here is my base project which is working fine :
#include <AFMotor.h>
#define trigPin 12
#define echoPin 13
AF_DCMotor motor1(1, MOTOR12_8KHZ);
AF_DCMotor motor2(2, MOTOR12_8KHZ);
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
motor1.setSpeed(200);
motor2.setSpeed (180);
long duration, distance;
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
duration = pulseIn(echoPin, HIGH);
distance = (duration / 2) / 29.1;
if (distance < 25) {
motor1.run(BACKWARD);
motor2.run (BACKWARD);
else if (distance < 40
motor2.run(FORWARD);
else{
delayMicroseconds (15);
motor1.run(FORWARD);
And here is my code which is not working. Actually if i try to test motor just with motor1.run(FORWARD);
Only one of those spins. Everything is well connected, because with my "base" project both motors spins well.
I already tried everything i could but i had no luck.
#define trigPin1 3
#define echoPin1 2
#define trigPin2 4
#define echoPin2 5
#define trigPin3 6
#define echoPin3 7
long duration1, duration2, duration3, distance1, distance2, distance3, RightSensor, FrontSensor, LeftSensor;
Serial.begin (9600);
pinMode(trigPin1, OUTPUT);
pinMode(echoPin1, INPUT);
pinMode(trigPin2, OUTPUT);
pinMode(echoPin2, INPUT);
pinMode(trigPin3, OUTPUT);
pinMode(echoPin3, INPUT);
motor1.setSpeed (200);
motor2.setSpeed (200);
SonarSensor(trigPin1, echoPin1);
FrontSensor = distance1;
SonarSensor(trigPin2, echoPin2);
RightSensor = distance2;
SonarSensor(trigPin3, echoPin3);
LeftSensor = distance3;
Serial.print(" Front ");
Serial.print(FrontSensor);
Serial.print(" Right ");
Serial.print(RightSensor);
Serial.print(" Left ");
Serial.println(LeftSensor);
void SonarSensor(int trigPin, int echoPin)
digitalWrite(trigPin1, LOW);
digitalWrite(trigPin1, HIGH);
duration1 = pulseIn(echoPin1, HIGH);
digitalWrite(trigPin2, LOW);
digitalWrite(trigPin2, HIGH);
duration2 = pulseIn(echoPin2, HIGH);
digitalWrite(trigPin3, LOW);
digitalWrite(trigPin3, HIGH);
duration3 = pulseIn(echoPin3, HIGH);
distance1 = (duration1 / 2) / 29.1;
distance2 = (duration2 / 2) / 29.1;
distance3 = (duration3 / 2) / 29.1;
// if (distance < 25) {
// motor1.run(BACKWARD);
// motor2.run (BACKWARD);
// else if (distance < 40
// motor2.run(FORWARD);
// else{
// delayMicroseconds (15);
// motor1.run(FORWARD);
