Arduino on a Breadboard - Only getting 3.6V
I'm new - so I hate to have to start a thread for a one-off issue, but I couldn't solve it with my own research.
I created a basic Arduino on a breadboard circuit to start to make my project permanent.
Issue - I am measuring 5V from my power supply...and 5V on the DC input jack, but when I test the circuit, I'm only getting 3.6V. I've quadruple checked the circuit setup. Where should I start to look? Can voltage regulators create such an issue?
Thanks!
Jeff
Without seeing a diagram (not a photo) of your circuit how can we know. A photo of a pencil drawing will be fine.
...R
jefffroehlich:
Yes.
The 5V regulator will drop the voltage a bit which is why the suggested voltage values start around 7V (I don't recall the exact value).
If your 5V supply is well regulated, you can power the Arduino using the 5V pin as a power input.
Thanks for the reply -
This is essentially the circuit I'm using (sorry...I'm at work - and don't have my board with me). In any case there was a piece of information I left out (and the exception to the diagram below). I am powering it using a 5V USB wall plug to a DC input jack on the breadboard. I am measuring using DC on my multimeter.
I don't like those Fritzing diagrams because I can't see what each of the Atmega pins is.
Why are there 2 connections to Vcc on the top of the diagram.
...R
"Why are there 2 connections to Vcc on the top of the diagram"
Probably has AREF Incorrectly connected to Vcc as well.
Just bypass the regulator. The USB 5V should be fine.
Fritzing has a schematic section. Many prefer a schematic over a wiring diagram.
It looks you have power flowing through the chip? DON"T do this. Use wires to bring power and ground to both sides of the breadboard if you'll be using both power rails.
Passing power through your microcontroller is a quick way to kill it (I know from personal experience).
Attached IMAGE.
This is exactly how I have the circuit wired. The part you can't see...
pin2 of the V regulator to GND
pin3 of the V regulator to POWER RAIL
10 uF across GND and POWER RAIL
The 100uF cap isn't shorted, even though it might look like it. It goes from row 3 to 4.
Missing 0.1uF decoupling caps on VCC and AVcc as well.
USB 5V is fine to power the VCC/AVCC pins directly, no regulator needed. That's how an Uno, etc is powered when connected to your PC. USB output voltage is 5V +/- 5%, so 4.75V to 5.25V. '328P is fine over that range.
Thanks guys.
Is the implication that my voltage regulator is likely the culprit here?
I don't want to abandon it, because the final design does not include powering it from USB.
Am I to assume I have a bad regulator?
No. You can't feed 5V into a regulator and get 5V out. You need more like 6 to 6.5V.
It's hard to kill a linear regulator unless you short its output to Gnd, or power it from 12V and draw lots of current and don't use a heatsink.
Ahhh - got it. So there's probably nothing wrong with my circuit - just that I'm not sending enough power through the regulator if I want 5V out.
So if my final design is to use a 5V USB car adapter from 12V - should I bypass the regulator all together and rely on the adapter to step it down?
Thanks.
"I'm not sending enough power "
No, you are not supplying with a high enough voltage for it to correctly regulate the output.
If you are using a 12V to 5V USB car adapter, then a regulator is not needed at all. Go try it - take your Uno, power it from USB port in your car. Same thing.
Pic from Reply #7 See Image Guide
Why is there such enthusiasm for useless modern style - a photo of a pencil drawing would be far more informative.
...R
