I'll get right to the point. my arduino should arrive any day now, but I wanted to build an arduino on a breadboard. It flat isn't working when I try to upload sketches with the IDE. it gives the following error:
avrdude: ser_open(): can't open device "\.\COM1": The system cannot find the file specified.
there some pictures of my setup as is.
My parts list is as follows:
- 1x270Ω resistor for LED
- 1xLED
- 2x22 PicoFarad ceramic capacitors (pins 8+9, 8+10)
- 1x16 MHz crystal oscillator (pins 9+10)
- 1x"5 pin usb-ttl converter" (TXD + Pin 3, RXD + Pin 2, 5V + VCC (pin 7), GND + GND (pin 8 ))
- 1xTactile Switch (between pin 1 + gnd)
I have no clue what to do or what the problem may be. I've tried pressing the tact switch connected to reset at multiple points before, after, and during the upload process, but the error never changes. I wish I had gotten a 6 pin USB to TTL version, but I only have this 5 pin veresion which has no DTR. what can I do to fix this?
