Arduino on Ice: Internet Radio via Shoutcast
I’ve seen plenty Internet Radio examples out there on various platforms, but none on Arduino. Is 2K memory just too little to stream radio effectively? Thought it was time to find out. Turns out it’s no problem at all. Using uIP on ENC28J60 for networking and VS1053 for playback, a stock ATmega328p-based Arduino can stream Internet Radio no problem with plenty RAM to spare.
On my blog is an example of a “Hello, world.” of Internet Radio. It starts up, connects to a single hard-coded stream, and plays it forever. This makes it simple! Plug and listen.
The key to making this project work was finding a small, memory-efficient TCP/IP stack in software that's mature and well-tested. For the longest time, I thought such a thing did not exist. Then I found uIP, which is part of the Contiki OS. More importantly, I found the avr-uip port which extracts uIP out of Contiki, and pairs it with the ENC28J60 driver. Even with all of its restrictions and compromises, it was able to download files from the web at 180kbytes/sec with only a 500-byte packet buffer. That's plenty fast enough to keep up with a 128kbits/sec Icecast stream with plenty of time left over for dealing with network hiccups.
Details: Arduino on Ice: Internet Radio via Shoutcast | maniacbug
Cool!
Hey, will not prompt in what could be the problem? I Arduino Mega 2560. I connected all the wires correctly, changing little global-conf.h I got to take data from the network, but there is no sound. When I disconnect reset appears sound but poor quality. Tried test sketch Audible "Hello" example for VS1003B + Microcontroller - VSDSP Forum # p308 I hear normal Hello, I actually have the same problem as in “arnulf” that will prompt I do? I’m sorry for bad english :slight_smile:
