Arduino only defines one variable set, and not both.
This code essentially is having two ultrasound sensors and a photo resistor work together to activate a relay.
My problem, is in defining the distance/duration variables
duration2 = pulseIn(echoPin2, HIGH);
distance2 = (duration2/2) / 29.1;
duration = pulseIn(echoPin, HIGH);
distance = (duration/2) / 29.1;
The Arduino only calculates the first set and ignores the second set. In the serial monitor it prints the "distance2" number, but for "distance", it only displays a 0. If I put the "distance" set first, then it is the opposite and "distance2" displays a 0.
#define trigPin 12
#define echoPin 13
#define trigPin2 10
#define echoPin2 11
int relay = 8;
int sensorPin = A0;
int sensorValue = 0;
Serial.begin (9600);
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
pinMode(trigPin2, OUTPUT);
pinMode(echoPin2, INPUT);
pinMode(relay, OUTPUT);
int duration, distance, sensorValue, duration2, distance2;
sensorValue = analogRead(sensorPin);
digitalWrite(trigPin, HIGH);
digitalWrite(trigPin2, HIGH);
delayMicroseconds(1000);
digitalWrite(trigPin, LOW);
digitalWrite(trigPin2, LOW);
if (distance >= 165 || distance <= 0 && distance2 >= 50 || distance <= 0 | sensorValue <= 900){
Serial.println("no object detected");
Serial.println(distance);
Serial.println(distance2);
Serial.println(sensorValue);
digitalWrite(relay, HIGH);
else {
Serial.println("object detected");
digitalWrite(relay, LOW);
delay (15000);
delay(100);
Note: to avoid echoes from the first sensor you should wait about 30 milliseconds between the first trigger and the second.
