Hi, I connected arduino sucessfully to android and I can change outputs(relays) from android phone using "TCP client" app by manually typing commands in. I was trying "Arduino Commander" app too , which seems very nice bit it didn't work unfortunately, it says "connecting 192.168.1.2:1234"...
Also, when I send " echo "(command)" >/dev/ttyACM0 " from WinSCP or PuTTY, arduino restarts,
any ideas?
That's normal behavior as the DTR signal (which the operating sets automatically when the device is opened) resets the Arduino (necessary for sketch upload).
What software do you run on the openwrt router (the software that talks to the Arduino)? Where are the links to these apps? I guess that "Arduino Commander" expects to talk to the Arduino directly and not by the OpenWRT router.
I couldn't find a link to that "Arduino Commander" app.
If you followed the linked guide, the IP should be 192.168.1.1 and not 192.168.1.2. If you configured your system differently you should mention all changes.
