arduino --> OSC
Hi everyone.
I'm new to arduino, and i was thinking if there is an easy way to send OSC messages from arduino.
Is there any library to load it to arduinoIDE?
As i understand from other posts in this forum there is no any simple way..
Maybe a java application like one made by monome team?
Hi, yeah, it is possible but (at least the way I'm doing it takes a little bit to set up). I really should write a proper write up some day... Anyway, the way I've been doing it is Arduino (with Firmata loaded onto it) => Python =>OSC.
So (and I'm sorry, this won't be very complete instructions because I've got far too much work to do :)):
Thing which need to be installed/done:
Python (www.python.org/)
pySerial (pyserial.sourceforge.net/)
pyOSC (V2_ Lab for the Unstable Media)
and put Firmata (Arduino Playground - Firmata) onto your Arduino.
Then stick these two in a folder:
pyduino.py (this is a slightly newer version than the one packaged on the Firmata page, there will be a new package for the 0011 release)
http://pyduino.pastebin.com/m60b2c529
arduino_osc.py
http://pyduino.pastebin.com/m5d9aca8d
Then if you run arduino_osc.py it should send osc values to /Arduino/Analog on the port you specify. It's pretty simple to add digital reading in too - if you read the pyduino and pyOSC code you should be able to work it out I think.
Sorry this is pretty minimal, but I hope it helps.
Joe
Ok. Thanks for the reply!
I will try it. .
Is it possible to program the arduino board with processing language with the OSC & arduino libraries ?
Haii,
can u please tell me the library function for counter module in arduino?
Thanks in advance
hi.
could you repost arduino_osc.py
i can't find it anywhere!
cheers.
+1, this code would be helpful but the pastebin link has expired (boo pastebin :frowning: )
mmm.
I found this link
http://recotana.com/recotanablog/?page_id=222
has anybody tried to do it on a pc?
a solid osc library could be the most valuable effort to make arduino being used by musicians and visualist using non-serial applications.
@giorgosS
I'm working on send OSC messages from arduino.
Here is the latest i've found where someone has gotten an arduino recieving osc:
http://asynclabs.com/forums/viewtopic.php?f=15&t=23
