Arduino output not stable
Hi all,
I am totally new to Arduino and getting my hands on a simple temperature sensor with LM35.
I connected the LM35 directly to Arduino based on the pin (5V, GND and A1). No pull up/down resistor, no capacitor involved.
I am powering up the Arduino via PC USB.
The issue that I faced here is I am getting intermittent reading. The reading fluctuates between 0 and approx 500mV of LM35.
I have tried:
  1. Measuring the PC USB port power using a USB power meter, It shows a stable 5.02V.
  2. Connecting to a AC-DC power source with 12V output using barrel jack on Arduino.
  3. Change another Arduino board.
Yet I am getting the same fluctuating output. Please help. Thank you so much in advance.
const int sensorPin = A1;
float sensorValue;
float vOut;
float tempC;
  pinMode(sensorPin, INPUT);
  sensorValue = analogRead(sensorPin);
  vOut = (sensorValue * 5000) / 1024;
  tempC = vOut / 10;
  Serial.print("Temperature(ºC): ");
  Serial.print(tempC);
  Serial.print("  Voltage(mV): ");
  Serial.println(vOut);
Output :
15:59:01.657 -> Temperature(ºC): 23.93  Voltage(mV): 239.26
15:59:02.643 -> Temperature(ºC): 0.00  Voltage(mV): 0.00
15:59:03.659 -> Temperature(ºC): 0.00  Voltage(mV): 0.00
15:59:04.644 -> Temperature(ºC): 25.88  Voltage(mV): 258.79
15:59:05.673 -> Temperature(ºC): 40.53  Voltage(mV): 405.27
15:59:06.657 -> Temperature(ºC): 41.99  Voltage(mV): 419.92
15:59:07.673 -> Temperature(ºC): 40.04  Voltage(mV): 400.39
15:59:08.661 -> Temperature(ºC): 36.62  Voltage(mV): 366.21
15:59:09.653 -> Temperature(ºC): 22.46  Voltage(mV): 224.61
15:59:10.670 -> Temperature(ºC): 0.00  Voltage(mV): 0.00
15:59:11.659 -> Temperature(ºC): 0.00  Voltage(mV): 0.00
15:59:12.657 -> Temperature(ºC): 0.00  Voltage(mV): 0.00
15:59:13.677 -> Temperature(ºC): 0.00  Voltage(mV): 0.00
15:59:14.666 -> Temperature(ºC): 0.00  Voltage(mV): 0.00
15:59:15.687 -> Temperature(ºC): 25.39  Voltage(mV): 253.91
15:59:16.679 -> Temperature(ºC): 40.53  Voltage(mV): 405.27
15:59:17.667 -> Temperature(ºC): 41.02  Voltage(mV): 410.16
15:59:18.687 -> Temperature(ºC): 40.53  Voltage(mV): 405.27
15:59:19.676 -> Temperature(ºC): 32.23  Voltage(mV): 322.27
15:59:20.691 -> Temperature(ºC): 0.00  Voltage(mV): 0.00
15:59:21.682 -> Temperature(ºC): 0.00  Voltage(mV): 0.00
15:59:22.680 -> Temperature(ºC): 0.00  Voltage(mV): 0.00
15:59:23.670 -> Temperature(ºC): 0.00  Voltage(mV): 0.00
15:59:24.691 -> Temperature(ºC): 0.00  Voltage(mV): 0.00
15:59:25.682 -> Temperature(ºC): 40.04  Voltage(mV): 400.39
15:59:26.705 -> Temperature(ºC): 41.02  Voltage(mV): 410.16
15:59:27.695 -> Temperature(ºC): 41.50  Voltage(mV): 415.04
15:59:28.684 -> Temperature(ºC): 36.62  Voltage(mV): 366.21
15:59:29.673 -> Temperature(ºC): 28.81  Voltage(mV): 288.09
15:59:30.693 -> Temperature(ºC): 0.00  Voltage(mV): 0.00
15:59:31.710 -> Temperature(ºC): 0.00  Voltage(mV): 0.00
15:59:32.673 -> Temperature(ºC): 0.00  Voltage(mV): 0.00
15:59:33.690 -> Temperature(ºC): 0.00  Voltage(mV): 0.00
15:59:34.676 -> Temperature(ºC): 0.00  Voltage(mV): 0.00
15:59:35.697 -> Temperature(ºC): 40.04  Voltage(mV): 400.39
15:59:36.707 -> Temperature(ºC): 40.53  Voltage(mV): 405.27
15:59:37.692 -> Temperature(ºC): 40.53  Voltage(mV): 405.27
15:59:38.712 -> Temperature(ºC): 37.11  Voltage(mV): 371.09
15:59:39.690 -> Temperature(ºC): 0.00  Voltage(mV): 0.00
15:59:40.712 -> Temperature(ºC): 0.00  Voltage(mV): 0.00
15:59:41.693 -> Temperature(ºC): 0.00  Voltage(mV): 0.00
15:59:42.682 -> Temperature(ºC): 0.00  Voltage(mV): 0.00
15:59:43.703 -> Temperature(ºC): 0.00  Voltage(mV): 0.00
Have you used a different sensor? Also try running a separate power supply to your sensor.
Also googled it and found a great guide. try reading it! LM35 Temperature Sensor Arduino Tutorial (3 Examples) (makerguides.com)
hi everone, thanks for your response.
Yes, i tried with another unit of LM35 also produce the same results. I am totally puzzled with this. I measure the voltage across LM35 Vout and GND from multimeter and it shows stable results. Just the Arduino output is fluctuating.
My guess would be a bad connection. Did you measure the sensor output voltage between the Arduino GND pin and the A1 pin?
Your code is a little too big
(Uncompiled untested)
const byte sensorPin = A1;
  int sensorValue = analogRead(sensorPin);
  float  vOut = (sensorValue * 5000UL) /  1024.0;
  float tempC = vOut / 10;
And yes, check your wiring.
Kudos for using the correct scale factor. But the UL is sort of a non sequitur here. 'sensorValue' is a float type so the whole expression is evaluated as a float expression.
My sensorValue is (correctly) an int.
In that case may I suggest
  float  vOut = sensorValue * (5000.0 / 1024.0);
which will work with either float or int.
Or maybe:
  float tempC = sensorValue * (5000.0 / 1024.0 / 10.0);
I think the issue when the reading goes to 0 is programmatic not connections or sensor.
I think the variations in readings (excluding the 0's) could be just noise. Maybe being aggravated by how you have it wired.
I would start with the analoginput example in the arduino IDE (see file/examples).
Then add a print statement printing out the raw analog read value.
If that all works start adding in your calculations.
Are you trying to take the temp of a liquid? Looks that way to me.
-jim lee
Sample code for the LM35 does not work for the most part. My students tried several, more like all, without success
Going to a digital temp sensor seemed the only solution until tried using the map function for the conversion.
If anyone is still interested in the LM35, this code works.
int value = analogRead(A0); //read analog value from LM35
int value2 = map(value,0,205,0,1023); //use map function to convert voltage
int celsius = value2/10, //divide by 10 for celsius
int farenhite = (celsius*9)/5 + 32; //conversion for farenhite
The output is stable using this code. Other examples jumped all around. Totally unusable
For the benefit of your students, sp. “Fahrenheit”
That doesn't seem right. That 'map()' is equivalent to multiplying by 1023/205 which is 4.99. With a 4.99V reference voltage that will get you "Volts * 1024" which is sort of close to millivolts but not quite. The proper calculation is:
const float AnalogReferenceMillivolts = 5020.0;  // Measured at the AREF pin
float millivolts = (analogRead(A0) * AnalogReferenceMillivolts) / 1024.0;
int celsius = (millivolts / 10.0) + 0.5;           // 10 millivolts per degree celsius, rounded
