I just want to inform that there is a rpm packet for Mandriva 2010.1 (spring) for Arduino 0018
It is available at the ftp of blogdrake:
http://blogdrake.serveftp.net/mandriva/2010.1/free/
The packet has various dependences. Then it is better to add the repository:
- noarch (required)
urpmi.addmedia --wget Bdk-noarch http://blogdrake.serveftp.net/mandriva/2010.1/free/noarch/ with media_info/synthesis.hdlist.cz
Depending on your architecture:
- i586
urpmi.addmedia --wget Bdk-i586 http://blogdrake.serveftp.net/mandriva/2010.1/free/i586/ with media_info/synthesis.hdlist.cz
or
- x86_64 (should be available shortly)
urpmi.addmedia --wget Bdk-x86_64 http://blogdrake.serveftp.net/mandriva/2010.1/free/x86_64/ with media_info/synthesis.hdlist.cz
Then, just "urpmi arduino" or use the rpmdrake gui
Arduino is not in noarch because it uses platform specific libraries for accessing the serial port.
The arduino packet: arduino-0018-1bdk2010.1.i586.rpm or arduino-0018-1bdk2010.1.x86_64.rpm needs also the following packets (dependences will be resolved automatically if you use the urpmi or rpmdrake installer GUI):
arduino-0018-1 avr-binutils-2.20.1-1 avr-gcc-4.4.3-4 avr-gcc-c++-4.4.3-4 avr-gdb-7.1-1
rxtx-nolock-2.2-0.1.pre2 avr-libc-1.7.0-9
When installed just execute "arduino" (or search for it at Development/IDEs). It sould run OK as an unprivileged user withoud modifying groups or permissions doe to a suid wrapper added fot this purpose)
x86-64 should run nativelly because the packet rxtx has platform-specific binaries of the librarie for accessing the serial port.
The packets are prepared for Mandriva but could be adapted to other distros. The sources can be downloaded from here:
http://blogdrake.serveftp.net/mandriva/SRPMS/arduino-http://blogdrake.serveftp.net/mandriva/SRPMS/0018-1bdk2010.1.src.rpm http://blogdrake.serveftp.net/mandriva/SRPMS/avr-binutils-http://blogdrake.serveftp.net/mandriva/SRPMS/2.20.1-1bdk2010.1.src.rpm http://blogdrake.serveftp.net/mandriva/SRPMS/avr-gcc-http://blogdrake.serveftp.net/mandriva/SRPMS/4.4.3-4bdk2010.1.src.rpm http://blogdrake.serveftp.net/mandriva/SRPMS/avr-gdb-http://blogdrake.serveftp.net/mandriva/SRPMS/7.1-1bdk2010.1.src.rpm http://blogdrake.serveftp.net/mandriva/SRPMS/avr-gdb-7.1-1bdk2010.src.rpm http://blogdrake.serveftp.net/mandriva/SRPMS/avr-libc-1.7.0-1bdk2010.1.src.rpm http://blogdrake.serveftp.net/mandriva/SRPMS/avr-libc-1.7.0-9bdk2010.1.src.rpm http://blogdrake.serveftp.net/mandriva/SRPMS/rxtx-nolock-http://blogdrake.serveftp.net/mandriva/SRPMS/2.2-0.1.pre2bdk2010.1.src.rpm
