Hi, I am fairly new to the world of Arduino. I have setup a system with my main structure as follows :
I have an arduino that is transmitting 10k samples at different baudrates. Arduino is just writing a value at serial port, here is its code :
int i;
//Initialize serial and wait for port to open:
//Serial.begin(38400);
Serial.begin(500000);
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
i = 0;
i++;
Serial.println(i);
if (i > 1000) {
while(true);
and I am reading it on my PC using python, for reading I am using this code :
class ReadLine:
def __init__(self, s):
self.buf = bytearray()
self.s = s
def readline(self):
i = self.buf.find(b"\n")
if i >= 0:
r = self.buf[:i+1]
self.buf = self.buf[i+1:]
return r
while True:
i = max(1, min(2048, self.s.in_waiting))
data = self.s.read(i)
i = data.find(b"\n")
if i >= 0:
r = self.buf + data[:i+1]
self.buf[0:] = data[i+1:]
return r
else:
self.buf.extend(data)
ser = serial.Serial(
port='COM4',\
baudrate=38400,\
timeout=0)
checker = 0
rl = ReadLine(ser)
while True:
time = datetime.now().strftime('%Y-%m-%d %H:%M:%S')
print(time)
print(checker)
print(rl.readline())
checker += 1
ser.close()
Now, if I use the above code and increase the baudrate above 38400, I start missing samples and I am not reading all of the samples on the PC side. Arduino card is Arduino Mega 2560 and I am using a i5 processor in PC. I am using python in Visual Studio.
Can some one please help me out why the samples are getting missed at higher baudrate ?
I have read about the Arduino card and it seems, it can support baudrate upto 500000 easily so it is because PC is lacking behind on serial port ?
Is there some efficient way to read over on the PC side ?
Also, if i use raspberry pi rather than a PC system will it help out for covering the missing samples over serial connection ?
If i use an ethernet connection will it be faster ?
Power_Broker:
Why? Python is cross-compatible - if it doesn't work on Windows, it surely won't work on Linux.
The problem is not that it is not working the problem is after increasing baudrates above 38400 the samples start dropping off, its like my system is unable to keep up with the baudrate of arduino. While at lesser baudrates it is getting all of the samples, so is it better to switch to SPI communication rather than UART one ?
nothan:
Have you tried the example in my link in Reply #1 - with a suitable modification of the serial port references the Python code should work on a Windows PC.
nothan:
I find it difficult to believe that your OS is not fast enough to handle higher baud rates unless you're running Windows 98 on a potato...
