Arduino Phone
Hey everyone! Basically I took apart an old landline telephone set and I found that the connections for a button being down is made on this little pad with squiggly copper that is joined when something conductive touches it. I was wondering if theres a way of using an arduino to emulate a button press with these pads by soldering to them. I don't want to have to use a bunch of relays, if possible.
I also want to control audio input and output with a NodeMCU, if possible. Any guidance would be appreciated
Edit: If possible could I also power the arduino from inside the phone? I know the input voltages change when the phone is hung up or not so idk if this is plausible
Symphonic:
Are you hinting that you wish to connect something you have made/modified to the land-line telephone system? If so, look at the criminal consequences to screwing up the public telephone system. Pick another project.
Paul
In a lot of places in the World you can only connect 'certified' equipment to public telephone networks.
The reasons for these restrictions are I would hope very clear for safety reasons alone ; engineers may be required to work on the telephone lines to correct faults.
Paul_KD7HB:
Paul
srnet:
This is going to be used on an intercom which is connected to the phone lines in an old building. I'm 99.9% sure it isnt connected to any public lines.
So, there is NO dial tone and NO ringing. Right?
Paul
Ah.. nevermind.
