Im having an arduino decimilia with an ATMega 328
#include <Wire.h>
#include <PID_v1.h>
double Setpoint, Input, Output,Setpoint1, Input1, Output1,Setpoint0, Input0, Output0,Setpoint2, Input2, Output2;
//double aggKp=4, aggKi=0.2, aggKd=1;
double consKp=1, consKi=2, consKd=0.1;
PID myPID(&Input, &Output, &Setpoint, consKp, consKi, consKd, DIRECT);//motor 4
PID myPID0(&Input0, &Output0, &Setpoint0, consKp, consKi, consKd, REVERSE);//motor 2
PID myPID1(&Input1, &Output1, &Setpoint1, consKp, consKi, consKd, DIRECT);//motor 3
PID myPID2(&Input2, &Output2, &Setpoint2, consKp, consKi, consKd, REVERSE);//motor 1
#include <Servo.h>
Servo g_servo1, g_servo2, g_servo3, g_servo4;
#define ACC (0x53)
#define A_TO_READ (6)
#define GYRO 0x69
#define G_SMPLRT_DIV 0x15
#define G_DLPF_FS 0x16
#define G_INT_CFG 0x17
#define G_PWR_MGM 0x3E
#define G_TO_READ 8
int g_offx = 120;
int g_offy = 20;
int g_offz = 93;
#define RAD_TO_DEG 57.295779513082320876798154814105
int x,y;
int gyroZeroX;
float gyroXadc;
float gyroXrate;
float gyroXangle;
int gyroZeroY;
float gyroYadc;
float gyroYrate;
float gyroYangle;
int gyroZeroZ;
float gyroZadc;
float gyroZrate;
float gyroZangle;
int accZeroX;
float accXadc;
float accXval;
float accXangle;
int accZeroY;
float accYadc;
float accYval;
float accYangle;
int accZeroZ;
float accZadc;
float accZval;
float accZangle;
float compAngleX;
float compAngleY;
float compAngleZ;
float R;
unsigned long timer=0;
unsigned long dtime=0;
int acc[3];
int gyro[4];
void getGyroscopeData(int * result)
int regAddress = 0x1B;
int temp, x, y, z;
byte buff[G_TO_READ];
readFrom(GYRO, regAddress, G_TO_READ, buff);
result[0] = ((buff[2] << 8) | buff[3]) + g_offx;
result[1] = ((buff[4] << 8) | buff[5]) + g_offy;
result[2] = ((buff[6] << 8) | buff[7]) + g_offz;
result[3] = (buff[0] << 8) | buff[1];
void initAcc() {
writeTo(ACC, 0x2D, 0);
writeTo(ACC, 0x2D, 16);
writeTo(ACC, 0x2D, 8);
void getAccelerometerData(int * result) {
int regAddress = 0x32;
byte buff[A_TO_READ];
readFrom(ACC, regAddress, A_TO_READ, buff);
result[0] = (((int)buff[1]) << 8) | buff[0];
result[1] = (((int)buff[3])<< 8) | buff[2];
result[2] = (((int)buff[5]) << 8) | buff[4];
void initGyro()
writeTo(GYRO, G_PWR_MGM, 0x00);
writeTo(GYRO, G_SMPLRT_DIV, 0x07);
writeTo(GYRO, G_DLPF_FS, 0x1E);
writeTo(GYRO, G_INT_CFG, 0x00);
g_servo1.attach(3);
g_servo2.attach(4);
g_servo3.attach(5);
g_servo4.attach(6);
Serial.begin(57600);
Wire.begin();
initAcc();
initGyro();
gyroZeroX = calibrateGyroX();
gyroZeroY = calibrateGyroY();
gyroZeroZ = calibrateGyroZ();
accZeroX = calibrateAccX();
accZeroY = calibrateAccY();
accZeroZ = calibrateAccZ();
/* myPID.SetMode(AUTOMATIC);
myPID1.SetMode(AUTOMATIC);
myPID0.SetMode(AUTOMATIC);
myPID2.SetMode(AUTOMATIC);
Input=x;
Input0=x;
Input1=y;
Input2=y;
Setpoint=3;
Setpoint0=3;
Setpoint1=-9;
Setpoint2=-9;
myPID.SetOutputLimits(63,80);
myPID1.SetOutputLimits(63,80);
myPID0.SetOutputLimits(63,80);
myPID2.SetOutputLimits(63,80);*/
timer=millis();
timer = millis();
if(timer<5000)
g_servo1.write(10);
g_servo3.write(10);
g_servo2.write(10);
g_servo4.write(10);
Serial.println(timer);
else{
getAccelerometerData(acc);
getGyroscopeData(gyro);
gyroXadc = gyro[0];
gyroXrate = (gyroXadc-gyroZeroX)/1.0323;
gyroYadc = gyro[1];
gyroYrate = (gyroYadc-gyroZeroY)/1.0323;
gyroZadc = gyro[2];
gyroZrate = (gyroZadc-gyroZeroZ)/1.0323;
accXadc = acc[0];
accXval = (accXadc-accZeroX)/102.3;
accYadc = acc[1];
accYval = (accYadc-accZeroY)/102.3;
accZadc = acc[2];
accZval = (accZadc-accZeroZ)/102.3;
accZval++;
R = sqrt(pow(accXval,2)+pow(accYval,2)+pow(accZval,2));
accXangle = acos(accXval/R)*RAD_TO_DEG-90;
accYangle = acos(accYval/R)*RAD_TO_DEG-90;
accZangle = acos(accZval/R)*RAD_TO_DEG;
dtime = millis()-timer;
timer = millis();
compAngleX = (0.98*(compAngleX+(gyroXrate*dtime/1000)))+(0.02*(accXangle));
compAngleY = (0.98*(compAngleY+(gyroYrate*dtime/1000)))+(0.02*(accYangle));
compAngleZ = (0.98*(compAngleZ+(gyroZrate*dtime/1000)))+(0.02*(accZangle));
x=compAngleX/100;
y=compAngleY/100;
/* Input=x;
Input0=x;
Input1=y;
Input2=y;
Setpoint=3;
Setpoint0=3;
Setpoint1=-9;
Setpoint2=-9;
myPID.SetTunings(consKp, consKi, consKd);
myPID0.SetTunings(consKp, consKi, consKd);
myPID1.SetTunings(consKp, consKi, consKd);
myPID2.SetTunings(consKp, consKi, consKd);
myPID.Compute();
myPID0.Compute();
myPID1.Compute();
myPID2.Compute();
g_servo4.write(Output);
g_servo2.write(Output0);
g_servo3.write(Output1);
g_servo1.write(Output2);*/
//Serial.print(Output);Serial.print("\t");Serial.print(Output0);Serial.print("\t");Serial.print(Output1);Serial.print("\t");Serial.print(Output2);Serial.println("");
Serial.print(x);Serial.print("\t");
Serial.print(y);Serial.print("\t");
Serial.print(compAngleZ);Serial.print("\t");
void writeTo(int DEVICE, byte address, byte val) {
Wire.beginTransmission(DEVICE);
Wire.send(address);
Wire.send(val);
Wire.endTransmission();
void readFrom(int DEVICE, byte address, int num, byte buff[]) {
Wire.send(address);
Wire.requestFrom(DEVICE, num);
int i = 0;
while(Wire.available())
buff[i] = Wire.receive();
i++;
