Arduino Pin Voltage Detection Problems
I was working on my own Arduino project and I was setting up a very simple switch. IE: 5V > switch > Pin; controlling Pin 13 (Built in LED). To start off, I didn't even have a switch, I was manually connecting the wires. The system worked fine, the LED lit up when I combined the wires. The only thing is, when I fidgeted the wire attached to the pin w/ the switch, the built in LED would light up most of the time, almost like there was a problem with that pin, but I connected it with many other pins and all of them have the same effect. My Arduino board is a few years old (Arduino Uno)...maybe that's why. Any help is greatly appreciated!
To get help, you must show us your complete sketch. Attach your code using the </> icon on the left side of the posting menu.
We also need to see a schematic.
You do have a 10K resistor from the pin to ground don't you?
I created a very basic test sketch to test out the issue:
pinMode(7, INPUT);
pinMode(13, OUTPUT);
if(digitalRead(7)==HIGH) {
digitalWrite(13, HIGH);
digitalWrite(13, LOW);
A wire is connected to pin 7, and another to 5V. I am manually simulating the switch by combining the wires. However, even before I combine any wires, just touching the wire connected to pin 7 will trip the program and light the led on pin 13; not consistently on, but it jutters on and off. Obviously, when I combine the wires the led turns on consistently.
I don't have any resistors set up, I was just following the tutorial on the Arduino website about switches.
Thanks!
(I have attached a Schematic as well)
add a 10k resistor from pin 7 to GND.
Review Mr. Gammon's page here:
As has been pointed out - you need to get used to the discipline of connecting switches between the pin - 7 in this case - and ground, setting the pinMode to INPUT_PULLUP and reading a LOW in the code when the switch is on.
Just fix your wiring and code to do this and you will be fine.
Okay I actually have some resistors laying around so I'll try it out, thanks for all the help!
hakasapl:
But you do not need them. Just wire and code it properly.
Look at the section that talks about "Internal pull-up resistor" in the link posted in reply 4.
