Hello Everyone
I have a Ping))) Sensor (hc-sr04) which is connected correctly and am using an Arduino UNO.
I start it up without being connected to ground (otherwise it doesn't even want to start) and it keeps writing 0 to the serial window (distance), once I plug in the ground pin, I get a few lines of correct distance readings and than it stops and hangs, no more results in the serial window, and the board itself seems to be in a fault state and I need to unplug it from the USB, disconnect the ground, and than re-plug to the USB
Does anyone have any ideas what can be the cause of the problem?
Thanks in advance!
Code:
#define echoPin 2 // Echo Pin
#define trigPin 4 // Trigger Pin
#define LEDPin 13 // Onboard LED
int maximumRange = 200; // Maximum range needed
int minimumRange = 0; // Minimum range needed
long duration, distance; // Duration used to calculate distance
int currentDistance = 0;
Serial.begin (9600);
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
pinMode(LEDPin, OUTPUT); // Use LED indicator (if required)
/* The following trigPin/echoPin cycle is used to determine the
distance of the nearest object by bouncing soundwaves off of it. */
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
duration = pulseIn(echoPin, HIGH);
//Calculate the distance (in cm) based on the speed of sound.
distance = duration/58.2;
if (distance >= maximumRange || distance <= minimumRange){
/* Send a negative number to computer and Turn LED ON
to indicate "out of range" */
Serial.println("-1");
digitalWrite(LEDPin, HIGH);
else {
/* Send the distance to the computer using Serial protocol, and
turn LED OFF to indicate successful reading. */
Serial.println(distance);
digitalWrite(LEDPin, LOW);
//Delay 50ms before next reading.
delay(50);
