I'm using an arduino with a ping sensor, that prints out to a gobetwino and to flash. It seems like it's giving too much information and gets lost in how much info the ping sensor gives out... but I also need it to detect things constantly. I was wondering if there is a way where the arduino prints a letter once the ping sensor picks up something under certain variables, but doesn't constantly say something is there. So if something is between 1 and 5 inches, it says "A" once, but will say "B" once the object is out of the range.
This alternates between 'A' and 'B', even though the funciton that returns sensorState evaluates true/false multiple times, neither 'A' nor 'B' will print multiple times.
void loop(){
//if sensor reading indicates a breach, AND the breach is unique - print A
if (readSensor()&&unique){
Serial.println("A");
unique=false;
//if sensor reading does not indicate a breach, AND the breach is not unique (or rather, was unique) - print B
else if(!readSensor()&&!unique){
Serial.println("B");
unique=true;
I’m having trouble incorporating the code with this…
Should I put the if statement found in the void loop into the readSensor() function?
edit: Basically I don’t understand the readSensor part
int pingPin = 4;
int serInLen = 25;
char serInString[25];
int pId =0;
int result;
boolean unique = true;
boolean sensorState = false;
Serial.println("#S|SPXL|[]#"); // start EXCEL
pId= atoi(serInString);
// convert result to integer
long duration, inches, cm;
char buffer[5];
// The PING))) is triggered by a HIGH pulse of 2 or more microseconds.
// We give a short LOW pulse beforehand to ensure a clean HIGH pulse.
pinMode(pingPin, OUTPUT);
digitalWrite(pingPin, LOW);
delayMicroseconds(2);
digitalWrite(pingPin, HIGH);
delayMicroseconds(5);
// The same pin is used to read the signal from the PING))): a HIGH
// pulse whose duration is the time (in microseconds) from the sending
// of the ping to the reception of its echo off of an object.
pinMode(pingPin, INPUT);
duration = pulseIn(pingPin, HIGH);
// convert the time into a distance
inches = microsecondsToInches(duration);
cm = microsecondsToCentimeters(duration);
if(cm>=1 && inches<=5)
Serial.print("#S|SENDK|[");
Serial.print(itoa((pId), buffer, 10));
Serial.print("&");
Serial.print("a");
Serial.println("]#");
Serial.println("#S|DLDATA|[]#");
//read a string from the serial and store it in an array
//you must supply the array variable - will return if timeOut ms passes before the sting is read so you should
//check the contents of the char array before making any assumptions.
long microsecondsToInches(long microseconds)
// According to Parallax's datasheet for the PING))), there are
// 73.746 microseconds per inch (i.e. sound travels at 1130 feet per
// second). This gives the distance travelled by the ping, outbound
// and return, so we divide by 2 to get the distance of the obstacle.
// See: http://www.parallax.com/dl/docs/prod/acc/28015-PING-v1.3.pdf
return microseconds / 74 / 2;
long microsecondsToCentimeters(long microseconds)
// The speed of sound is 340 m/s or 29 microseconds per centimeter.
// The ping travels out and back, so to find the distance of the
// object we take half of the distance travelled.
return microseconds / 29 / 2;
boolean readSensor(){
millis()%1000 == 0 ? sensorState=!sensorState : sensorState;
return sensorState;
void readSerialString (char *strArray,long timeOut)
long startTime=millis();
int i;
while (!Serial.available()) {
if (millis()-startTime >= timeOut) {
return;
while (Serial.available() && i < serInLen) {
strArray[i] = Serial.read();
i++;
int pingPin = 4;
int serInLen = 25;
int pId =0;
int result;
char buffer[5];
if(cm>=1 && inches<=5 &&unique)
Serial.print("&");
Serial.print("a");
unique=false;
else if (inches>5 &&!unique)
Serial.print("&");
Serial.print("b");
unique=true;
delay(100);
int i;
return;
i++;
