Arduino pins not working or something like that
HI, I was making a sequential LED project. I connected two LEDs to pin Number 5 and 6. But the LED didn't turn on, so I thought it might be the resistor, I was using a 100ohm resistor, but it was not the problem. so, I changed the LED two times, it didn't work. So, I thought it might be the pins I tested them with a red LED and it worked (I used a white and green LED before testing the red led and they didn't work). So, what do you guys think the problem is?
Code, wiring?
Power supply ?
@paulpaulson power from my pc
@killzone_kid
#define delay50 100
int myled[] = {2, 3, 4, 5, 6};
int num_of_leds;
  num_of_leds = sizeof(myled) / sizeof(int);
  for (int i = 0; i < num_of_leds; i++) {
    pinMode(myled[i], OUTPUT);
  ledonn();
  delay(2000);
  ledoff();
  delay(2000);
  for (int i = 0; i < 5; i++) {pattern1();}
  for (int i = 0; i < 5; i++) {pattern2();}
  for (int i = 0; i < 5; i++) {pattern3();}
  for (int i = 0; i < 5; i++) {pattern4();}
  for (int i = 0; i < 25; i++){pattern5();}
  for (int i = 0; i < 5; i++) {pattern6();}
  for (int i = 0; i < 15; i++){pattern7();}
  for (int i = 0; i < 15; i++){pattern8();}
  for (int i = 0; i < 5; i++) {pattern9();}
  for (int i = 0; i < 5; i++) {pattern10();}
  for (int i = 0; i < 50; i++){pattern11();}
  for (int i = 0; i < 50; i++){pattern12();}
  ledoff();
  delay(5000);
//TURN ON ALL LEDs
void ledonn() {
    digitalWrite(myled[i], HIGH);
//TURN OFF ALL LEDs
void ledoff() {
    digitalWrite(myled[i], LOW);
//LEFT TO RIGHT
void pattern1() {
    delay(delay50);
//RIGHT TO LEFT
void pattern2() {
  for (int i = num_of_leds; i > 0; i--) {
    digitalWrite(myled[i - 1], HIGH);
    delay(delay50);
    digitalWrite(myled[i - 1], LOW);
//LEFT TO RIGHT FILL
void pattern3() {
    delay(delay50);
    delay(delay50);
//RIGHT TO LEFT FILL
void pattern4() {
  ledonn();
  delay(delay50);
    delay(delay50);
    delay(delay50);
  ledoff();
//ALTERNATE LEDs
void pattern5() {
  for (int i = 0; i < num_of_leds; i = i + 2) {
    digitalWrite(myled[i + 1], LOW);
  delay(delay50);
    digitalWrite(myled[i + 1], HIGH);
  delay(delay50);
//OSCILLATING LEDs
void pattern6() {   //osc
    delay(delay50);
  delay(delay50);
    delay(delay50);
//INSIDE
void pattern7() {
  for (int i = 0; i < num_of_leds / 2; i++) {
    digitalWrite(myled[num_of_leds - 1 - i], HIGH);
    delay(delay50);
    digitalWrite(myled[num_of_leds - 1 - i], LOW);
//OUTSIDE
void pattern8()
  for (int i = (num_of_leds / 2) - 1; i >= 0 ; i--)
    delay(delay50);
//LEFT TO RIGHT 3 LEDs
void pattern9() {
  for (int i = 0; i < num_of_leds + 3; i++) {
    if (i <= num_of_leds) {
    if (i > 2) {
      digitalWrite(myled[i - 3], LOW);
    delay(delay50);
//OSCILLATING 3 LEDs
void pattern10() {
  for (int i = 2; i < num_of_leds; i++) {
    if (i == 2) {
      digitalWrite(myled[0], HIGH);
      digitalWrite(myled[1], HIGH);
    delay(delay50);
  for (int i = num_of_leds - 4; i > -1; i--) {
    digitalWrite(myled[i + 3], LOW);
    delay(delay50);
//RANDOM EFFECT 1
void pattern11() {
  int randomnum = random(0, num_of_leds + 1);
  digitalWrite(myled[randomnum], HIGH);
  delay(delay50);
  digitalWrite(myled[randomnum], LOW);
  delay(delay50);
//RANDOM EFFECT 2
void pattern12() {
  int randomonn = random(0, num_of_leds + 1);
  int randomoff = random(0, num_of_leds + 1);
  digitalWrite(myled[randomonn], HIGH);
  digitalWrite(myled[randomoff], LOW);
  delay(delay50);
this is the code all the wiring is correct
so if you use all red LEDs, it works as expected?
@killzone_kid if I connect only the red Leds yes, they do work as expected
White and green LEDs have a higher forward voltage than red LEDs.
so, i was drawing too much voltage. if so, how can i use those leds
Did you try turning the LED around 180 degrees?
Could be bad LEDs, they will burn out if used without current limiting resistors, and 100 ohms may allow too much current to flow.
if you meant if I connected positive and negative correctly, I did. But I tested with other white Leds, the results were the same
turn all pins on and connect your LEDs, the ones that don’t light, reduce resistor values until they light
i'll try and reply
You can't draw voltage, you draw current. I suspect the supply voltage to the Arduino is insufficient for the white/green LEDs - what voltage are you measuring there?
when i tried using resistors down to 10 ohms they didn't work. so i connected them directly to the pin, then the green led started to glow slightly. the white led still didn't glow
I don't know the exact voltage as i don't have a multimeter. it is from the usb port on the back of my pc, i think it is 5v 1A.
Which Arduino are you using?
uno r3
what kind of LEDs are they
5mm leds
