Arduino pitches.H
Hi, I was wondering if someone could please help me with this code, it is due in one week for a school project. I keep getting an error message that says “pitches.h” was not declared in this scope. I just started using Arduino and I’m not too good at it yet, so I was hoping that someone might be able to help me or give me some pointers on how to fix it.
Anyway, here’s the code and the file:
//Use pushbotton as a toggle switch.
//When the pushbotton is pressed, the pushbotton pin reads a
//high voltage and then a low voltage, and then ledOn is set
//to the opposite of its current value (either false or true).
//Based on Starter Kit Project 02.
#include “pitches.h”
const int soundPin = A0; //sound sensor attach to A0
const int piezoPin = 12; //piezo
const int rPin = 5; //red LED
const int gPin = 4; //green LED
const int bPin = 3; //blue LED
const int pPin = 2; //pushbutton
int ledState = 0;
int ledOn = false;
// notes
int melody = {
NOTE_C4, NOTE_C4, NOTE_G4, NOTE_G4, NOTE_A4, NOTE_A4, NOTE_G4, NOTE_F5, NOTE_F5, NOTE_E4,
NOTE_E4, NOTE_D4, NOTE_D4, NOTE_C4};
// durations: 2 = quarter note, 1 = whole note, 3 = half note
float noteDurations = {
2, 2, 2, 2, 2, 2, 1, 2, 2, 2, 2, 2, 2, 1,
// calculates the number of elements in the melody array.
int musicLength=sizeof(melody)/sizeof(‘NOTE_F5’);
pinMode(pPin, INPUT);
pinMode(rPin, OUTPUT);
pinMode(gPin, OUTPUT);
pinMode(bPin, OUTPUT);
int pPinState=digitalRead(pPin);
if(pPinState==HIGH) {
ledState = 1;
int value = analogRead(soundPin); //read the value of sound sensor
Serial.println(value);//print it
if (pPinState==LOW and ledState ==1) {
ledState = 2;
ledOn = not ledOn;
if(ledOn && pPinState!=HIGH) {
for (int thisNote = 0; thisNote < musicLength; thisNote++) {
// blink the three LEDs in sequence
if (thisNote%3==0){
digitalWrite(rPin, HIGH);
digitalWrite(gPin, LOW);
digitalWrite(bPin, LOW);
else if (thisNote%3==1){
digitalWrite(rPin, LOW);
digitalWrite(gPin, HIGH);
else if (thisNote%3==2){
digitalWrite(bPin, HIGH);
// calculate the note duration. change tempo by changing 2000 to other values
int noteDuration = 1000/noteDurations[thisNote];
tone(piezoPin, melody[thisNote],noteDuration);
// to distinguish the notes, set a minimum time between them.
// the note’s duration + 30% seems to work well
float pauseBetweenNotes = noteDuration * 1.30;
//split the delay into two parts and check to see
//whether the pushbutton is pressed to turn off
//the sound and light
delay(pauseBetweenNotes/2);
if(digitalRead(pPin)==HIGH) {
else if (not ledOn) {
This is the file that I have hooked up to the code:
  • Public Constants
#define NOTE_B0 31
#define NOTE_C1 33
#define NOTE_CS1 35
#define NOTE_D1 37
#define NOTE_DS1 39
#define NOTE_E1 41
#define NOTE_F1 44
#define NOTE_FS1 46
#define NOTE_G1 49
#define NOTE_GS1 52
#define NOTE_A1 55
#define NOTE_AS1 58
#define NOTE_B1 62
#define NOTE_C2 65
#define NOTE_CS2 69
#define NOTE_D2 73
#define NOTE_DS2 78
#define NOTE_E2 82
#define NOTE_F2 87
#define NOTE_FS2 93
#define NOTE_G2 98
#define NOTE_GS2 104
#define NOTE_A2 110
#define NOTE_AS2 117
#define NOTE_B2 123
#define NOTE_C4 131
#define NOTE_CS3 139
#define NOTE_D3 147
#define NOTE_DS3 156
#define NOTE_E3 165
#define NOTE_F3 175
#define NOTE_FS3 185
#define NOTE_G3 196
#define NOTE_GS3 208
#define NOTE_A3 220
#define NOTE_AS3 233
#define NOTE_B3 247
#define NOTE_C4 262
#define NOTE_CS4 277
#define NOTE_D4 294
#define NOTE_DS4 311
#define NOTE_E4 330
#define NOTE_F4 349
#define NOTE_FS4 370
#define NOTE_G4 392
#define NOTE_GS4 415
#define NOTE_A4 440
#define NOTE_AS4 466
#define NOTE_B4 494
#define NOTE_C5 523
#define NOTE_CS5 554
#define NOTE_D5 587
#define NOTE_DS5 622
#define NOTE_E5 659
#define NOTE_F5 698
#define NOTE_FS5 740
#define NOTE_G5 784
#define NOTE_GS5 831
#define NOTE_A5 880
#define NOTE_AS5 932
#define NOTE_B5 988
#define NOTE_C6 1047
#define NOTE_CS6 1109
#define NOTE_D6 1175
#define NOTE_DS6 1245
#define NOTE_E6 1319
#define NOTE_F6 1397
#define NOTE_FS6 1480
#define NOTE_G6 1568
#define NOTE_GS6 1661
#define NOTE_A6 1760
#define NOTE_AS6 1865
#define NOTE_B6 1976
#define NOTE_C7 2093
#define NOTE_CS7 2217
#define NOTE_D7 2349
#define NOTE_DS7 2489
#define NOTE_E7 2637
#define NOTE_F7 2794
#define NOTE_FS7 2960
#define NOTE_G7 3136
#define NOTE_GS7 3322
#define NOTE_A7 3520
#define NOTE_AS7 3729
#define NOTE_B7 3951
#define NOTE_C8 4186
#define NOTE_CS8 4435
#define NOTE_D8 4699
#define NOTE_DS8 4978
TOPIC SPLIT.
Do NOT HIJACK another thread especially if it is not related.
Please READ THIS POST for future reference. Then you may MODIFY your original post for the code etc.
Additionally it is not our place to do your homework for you.
Bob.
Post the actual error message you get and describe exactly how you "hooked up to the code" that text you posted.
Steve
Hi, Welcome to the forum.
Please read the first post in any forum entitled how to use this forum. http://forum.arduino.cc/index.php/topic,148850.0.html . Then look down to item #7 about how to post your code. It will be formatted in a scrolling window that makes it easier to read.
Thanks... Tom... :)
What is 'hooked up'? What is the filename of that file? Where is it located?
