Below is a simple Arduino code that well send an analog reading every two seconds and toggle the built in led when an 'x' is received.
const uint32_t interval = 2000;
const byte ledPin = LED_BUILTIN;
Serial.begin(57600);
digitalWrite(ledPin, LOW);
pinMode(ledPin, OUTPUT);
static uint32_t nextTime;
if (millis() >= nextTime)
nextTime += interval;
int x = analogRead(A0);
Serial.print("<");
Serial.print(x);
Serial.print(">");
if (Serial.available() > 0)
char ch = Serial.read();
if (ch == 'x')
digitalWrite(ledPin, !digitalRead(ledPin));
Next create a C# winform application.
- Add a menu bar and a status bar to the form.
- Add a groupbox to the form, set the text property to Serial Data and rename it from groupBox1 to gbSerialData.
- Add a textbox inside the groupbox; rename it from textBox1 to tbSerialIn.
- Add a button, rename it from button1 to btnAction; set the text property to Action.
- Add a backgroundworker to the form and rename it from backgroundWorker1 to bwSerial.
- Click the status bar, in the status bar, click the little dropdown box and add a status label; rename the status label from toolStripStatusLabel1 to slCom.
- Add a menu item called &Port to the menu bar and under it an item to open the port (&Open) and an item to close the port (&Close).
Motivation for the renaming: it's clearer to what the function of an object is and it's easier to refer to it. E.g. textBox1 does not mean much if you have plenty text boxes, tbSerialIn straight away tells you that it's the text box for the serial data. I usually go a little futher with the renaming which would include renaming of menu items etc. But this should be enough for the demo code.
To be able to use non-blocking code in the C# application, I've choosen to use a backgroundworker for the receiving of serial data.
Below is the code for the mainForm
using System;
using System.ComponentModel;
using System.Windows.Forms;
using System.IO.Ports;
namespace ArduinoSerial_855804_1
public partial class mainForm : Form
/// <summary>
/// serial port object
/// </summary>
static SerialPort sp = new SerialPort();
/// <summary>
/// delegate to be able to update textbox from background worker thread
/// </summary>
/// <param name="text"></param>
private delegate void SafeCallDelegate(string text);
#region form
public mainForm()
InitializeComponent();
// setup the background worker process for the serial reading
bwSerial.WorkerSupportsCancellation = true;
bwSerial.DoWork += new DoWorkEventHandler(bwSerial_DoWork);
bwSerial.RunWorkerCompleted += new RunWorkerCompletedEventHandler(bwSerial_RunWorkerCompleted);
/// <summary>
/// when the user closed the form, cancel the background worker
/// </summary>
/// <param name="sender"></param>
/// <param name="e"></param>
private void mainForm_FormClosing(object sender, FormClosingEventArgs e)
try
if (sp.IsOpen == true)
if (bwSerial.WorkerSupportsCancellation == true)
// Cancel the asynchronous operation.
bwSerial.CancelAsync();
catch (Exception ex)
MessageBox.Show(ex.Message);
#endregion form
#region menu
private void openToolStripMenuItem_Click(object sender, EventArgs e)
if (sp.IsOpen == false)
try
sp.PortName = "COM8";
sp.BaudRate = 57600;
sp.Parity = Parity.None;
sp.DataBits = 8;
sp.StopBits = StopBits.One;
sp.DtrEnable = false;
sp.Open();
slCom.Text = sp.PortName + " open";
if (bwSerial.IsBusy != true)
// Start the asynchronous operation.
bwSerial.RunWorkerAsync();
catch(Exception ex)
private void closeToolStripMenuItem_Click(object sender, EventArgs e)
try
//sp.Close();
//slCom.Text = sp.PortName + " closed";
private void exitToolStripMenuItem_Click(object sender, EventArgs e)
this.Close();
#endregion menu
#region serial receive
/// <summary>
/// do the serial reading in the background
/// </summary>
private void bwSerial_DoWork(object sender, DoWorkEventArgs e)
BackgroundWorker worker = sender as BackgroundWorker;
// run forever
while (true)
// if operation canceled (close serial port selected in menu or form closed)
if (worker.CancellationPending == true)
e.Cancel = true;
// read up to '>'
string data = sp.ReadTo(">");
// if the first character wasn't '<'
if (data[0] != '<')
// ignore
continue;
// get the value
string value = data.Substring(1);
// update the textbox that displays the analog vaue
UpdateTextbox(value);
/// <summary>
/// run when the background process is completed; this will only happen
/// when we indicate that we want to close the serial port from the menu
/// or when we close the form
/// or on error
/// </summary>
private void bwSerial_RunWorkerCompleted(object sender, RunWorkerCompletedEventArgs e)
if (e.Cancelled == true)
slCom.Text = "Canceled!";
sp.Close();
else if (e.Error != null)
slCom.Text = "Error: " + e.Error.Message;
sp.Close();
//slCom.Text = "Done!";
#endregion serial receive
#region buttons
/// <summary>
/// initiate action on Arduino
/// </summary>
private void btnAction_Click(object sender, EventArgs e)
sp.Write("x");
#endregion buttons
#region helpers
/// <summary>
/// update the textbox with the text received from the Arduino
/// </summary>
private void UpdateTextbox(string text)
if (tbSerialIn.InvokeRequired)
var d = new SafeCallDelegate(UpdateTextbox);
tbSerialIn.Invoke(d, new object[] { text });
tbSerialIn.Text = text;
#endregion helpers
The code uses the Port -> Open menu item to open the port and start the background process. It uses the menu item Port -> Close to stop the background process and next close the port. The serial port settings are hard-coded, I'm reasonably sure that I have seen examples on the web to make it configurable; note that my port is set COM8.
One problem with background code is that it can not directly 'communicate' with the foreground (the UI); hence the use of a so-called delegate.
The code has some hardening (catching exceptions) but probably incomplete.
That's it, if you have questions, let me know. Full project, written in VS2017, attached.
ArduinoSerial_855804_1.zip (393.8 KB)
